Thread: Probleem met cod en cod uo
26-11-2004, 00:36 #1
Yo ik heb net deze 2 games gekocht en ik kom thuis, ik wil ze installen, dat lukt perfect en daarna klik ik op play SP en hij zegt 17 sound files missing
ik klik op mp en dezelfde fout melding dan probeer ik het bij cod uo en daar geeft hij ook 2 keer dezelfde
kan iemand mij aub helpen???
dit geeft hij in een console
COD 1.0 build win-x86 Oct 5 2003
----- FS_Startup -----
Current language: english
Current search path:
D:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files)
D:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files)
D:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files)
D:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
D:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files)
D:\PROGRA~1\CALLOF~1\main\pak0.pk3 (12828 files)
D:\PROGRA~1\CALLOF~1/main
D:\PROGRA~1\CALLOF~1\main\localized_english_pak1.p k3 (3736 files)
localized assets pak file for english
D:\PROGRA~1\CALLOF~1\main\localized_english_pak0.p k3 (1204 files)
File Handles:
28931 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec config.cfg
couldn't exec autoexec.cfg
========= autoconfigure
configure.csv: using configuration 2000 cpu MHz 512 sys MB 128 vid MB
execing configure.cfg
fs_basepath is write protected.
fs_homepath is write protected.
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Measured CPU speed is 2.01 GHz
System memory is 512 MB (capped at 1 GB)
Video card memory is 128 MB
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 6: 1024 768 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...99 PFDs found
...hardware acceleration found
...PIXELFORMAT 5 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...ignoring OpenGL 1.2 draw element range
...using OpenGL 1.3 texture add environment mode
...using OpenGL 1.3 texture combine environment mode
...using OpenGL 1.3 texture dot3 environment mode
...using OpenGL 1.3 cube map textures
...using GL_ARB_vertex_program
...GL_NV_texture_shader not found
...GL_NV_register_combiners not found
...using WGL_EXT_swap_control
...using OpenGL 1.3 multitexture
...using GL_EXT_compiled_vertex_array
...using OpenGL 1.2 normal rescaling
...GL_ATI_pn_triangles not found
...using GL_ARB_vertex_buffer_object
...GL_NV_fog_distance not found
...GL_NV_vertex_array_range not found
...GL_NV_fence not found
...ignoring GL_ATI_vertex_array_object
...using GL_ATI_fragment_shader
...ignoring GL_EXT_texture_filter_anisotropic
GL_VENDOR: ATI Technologies Inc.
GL_RENDERER: RADEON 9800 Pro x86/MMX/3DNow!/SSE2
GL_VERSION: 1.5.4773 WinXP Release
GL_EXTENSIONS: GL_ARB_multitexture GL_EXT_texture_env_add GL_EXT_compiled_vertex_array GL_S3_s3tc GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_multisample GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_element_array GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_map_object_buffer GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_ATI_vertex_array_object GL_ATI_vertex_attrib_array_object GL_ATI_vertex_streams GL_ATIX_texture_env_combine3 GL_ATIX_texture_env_route GL_ATIX_vertex_shader_output_point_size GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_EXT_vertex_shader GL_HP_occlusion_test GL_NV_texgen_reflection GL_NV_blend_square GL_NV_occlusion_query GL_SGI_color_matrix GL_SGIS_texture_edge_clamp GL_SGIS_texture_border_clamp GL_SGIS_texture_lod GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_extensions_string WGL_EXT_swap_control
WGL_EXTENSIONS: WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_extensions_string WGL_EXT_swap_control WGL_ATI_render_texture_rectangle
GL_MAX_TEXTURE_SIZE: 2048
GL_MAX_ACTIVE_TEXTURES_ARB: 8
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(8-bits)
MODE: 6, 1024 x 768 fullscreen hz:60
GAMMA: hardware w/ 0 overbright bits
CPU: AMD w/ 3DNow!
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
picmip2: 1
texture bits: 0
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
ATI truform: disabled
NV distance fog: disabled
Initializing Shaders
...loading 'scripts/brad.shader'
...loading 'scripts/carride.shader'
...loading 'scripts/cloudshadow.shader'
...loading 'scripts/common.shader'
...loading 'scripts/decals.shader'
...loading 'scripts/effects.shader'
...loading 'scripts/gfx.shader'
...loading 'scripts/hood.shader'
...loading 'scripts/hud.shader'
...loading 'scripts/jeff.shader'
...loading 'scripts/nodlight.shader'
...loading 'scripts/paulj.shader'
...loading 'scripts/river_pj.shader'
...loading 'scripts/sfx.shader'
...loading 'scripts/sky.shader'
...loading 'scripts/sun.shader'
...loading 'scripts/surfacelight.shader'
...loading 'scripts/talon.shader'
...loading 'scripts/tankcountry.shader'
...loading 'scripts/tankhud.shader'
...loading 'scripts/terrain.shader'
...loading 'scripts/test.shader'
...loading 'scripts/transparents.shader'
...loading 'scripts/treeshadowtest.shader'
...loading 'scripts/truckride.shader'
...loading 'scripts/ui_hud.shader'
...loading 'scripts/ui_menus.shader'
...loading 'scripts/ui_menus_mp.shader'
...loading 'scripts/water.shader'
...loading 'scripts/weapons.shader'
...loading 'fxshaders/jh_fx.shader'
...loading 'fxshaders/pj_fx.shader'
...loading 'fxshaders/pj_impact.shader'
...loading 'fxshaders/weaponfx.shader'
----- finished R_Init -----
------- Miles sound system initialization -------
Attempting 44 kHz 16 bit stereo sound
2D provider initialized at 21968728 1991200347 34012532
available 3D providers:
Aureal A3D Interactive (TM)
Aureal A3D 2.0 (TM)
DirectSound3D Software Emulation
DirectSound3D Hardware Support
DirectSound3D 7+ Software - Pan and Volume
DirectSound3D 7+ Software - Light HRTF
DirectSound3D 7+ Software - Full HRTF
Creative Labs EAX 3 (TM)
Creative Labs EAX 2 (TM)
Creative Labs EAX (TM)
RAD Game Tools RSX 3D Audio
Dolby Surround
Miles Fast 2D Positional Audio
using 3D provider 'Miles Fast 2D Positional Audio'
32 max 3D channels
------- Miles successfully initialized -------
Sound file 'sound/vehicles/crashes/metal_crash.wav' not found
WARNING: loaded sound file 'sound/vehicles/crashes/metal_crash.wav' couldn't be read
WARNING: streamed sound 'sound/fire/Fire_Big_loop02.wav' not found
Sound file 'sound/explosions/explo_rock01.wav' not found
WARNING: loaded sound file 'sound/explosions/explo_rock01.wav' couldn't be read
Sound file 'sound/explosions/explo_rock02.wav' not found
WARNING: loaded sound file 'sound/explosions/explo_rock02.wav' couldn't be read
WARNING: streamed sound 'sound/fire/Fire_med_loop02.wav' not found
Sound file 'sound/explosions/mortar_dirt01.wav' not found
WARNING: loaded sound file 'sound/explosions/mortar_dirt01.wav' couldn't be read
Sound file 'sound/explosions/mortar_dirt02.wav' not found
WARNING: loaded sound file 'sound/explosions/mortar_dirt02.wav' couldn't be read
Sound file 'sound/explosions/mortar_dirt03.wav' not found
WARNING: loaded sound file 'sound/explosions/mortar_dirt03.wav' couldn't be read
Sound file 'sound/explosions/mortar_dirt04.wav' not found
WARNING: loaded sound file 'sound/explosions/mortar_dirt04.wav' couldn't be read
Sound file 'sound/explosions/mortar_dirt05.wav' not found
WARNING: loaded sound file 'sound/explosions/mortar_dirt05.wav' couldn't be read
Sound file 'sound/explosions/mortar_dirt06.wav' not found
WARNING: loaded sound file 'sound/explosions/mortar_dirt06.wav' couldn't be read
Sound file 'sound/misc/mouse_click.wav' not found
WARNING: loaded sound file 'sound/misc/mouse_click.wav' couldn't be read
Sound file 'sound/misc/mouse_over.wav' not found
WARNING: loaded sound file 'sound/misc/mouse_over.wav' couldn't be read
WARNING: streamed sound 'sound/music/mainmenu1.mp3' not found
Sound file 'sound/vehicles/turret_spin_01.wav' not found
WARNING: loaded sound file 'sound/vehicles/turret_spin_01.wav' couldn't be read
Sound file 'sound/vehicles/turret_end_01.wav' not found
WARNING: loaded sound file 'sound/vehicles/turret_end_01.wav' couldn't be read
Sound file 'sound/vehicles/crashes/gate_crash.wav' not found
WARNING: loaded sound file 'sound/vehicles/crashes/gate_crash.wav' couldn't be read
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
17 sound file(s) are missing or in a bad formatno votes
26-11-2004, 08:11 #2
al gereïnstalled?
eerst cod, dan uo he...kusjeno votes
26-11-2004, 13:33 #3
ja kheb al cod en uo gereinstalled en derna alleen cod is ne keer mr hij geeft et elke keer
26-11-2004, 13:54 #4Approved 9-lifer
- 18/07/02
- Willebroek
- 8,362
- 124 (96%)
- 2/6
de patch voor COD al eens proberen installeren?
Anders eens proberen te installeren vanuit een andere cd/dvd rom...Last.fm
PSN: lennert1984no votes
26-11-2004, 14:16 #5
https://activision.custhelp.com/cgi-...i=&p_topview=1
meer bepaald :
Copy the PAK files from disc 2 to your PC.
1) Place Call of Duty disc 2 in the CD-ROM drive.
2) Open My Computer.
3) Right-click on the Call of Duty CD and select Open.
4) Open the Setup folder on the CD.
5) Open My Computer again.
6) Open the Call of Duty folder on your hard drive, C:\Program Files\Call of Duty.
7) Copy the MAIN folder from the CD-ROM drive into the Call of Duty folder.
8) If prompted to overwrite files, do so.Service guarantees citizenship.no votes
26-11-2004, 17:31 #6
pff als em pak2 aant overzetten is dan geeft hij een error
26-11-2004, 17:32 #7
beschadigd bestand kan ook aan cd zelf liggen
26-11-2004, 17:34 #8
hmm
zou iemand mij anders wille toevoege en da doorsture via msn ??
want kzou et graag wille spelen :'( indien ge mij wilt toevoege --> nicolas_malisse@hotmail.com
26-11-2004, 17:42 #9
Of... is ne keer online zetten op een webspace...
26-11-2004, 17:43 #10Member
- 14/09/02
- Hoogstraten
- 2,488
.:. Join Boinc.be, the best Belgian crunching team.:.
.:. 9lives.be nieuwsposter .:. 9lives.be PS3 reviewer.:. PSN ID: Mich_be .:.
26-11-2004, 17:45 #11
euhm iets in de 100 kb volges mij... want de andere zen ook zo groot dus... alé de andere zen 100.000 kb kan dus wel meer zen mr kwni ofda da een punt of een komma is ... tstaat in u cod map en dan main en daar sta da bestandje in... as ge da zou wille doen echt thx
26-11-2004, 17:48 #12
~150MB dus
26-11-2004, 17:49 #13
zou kunne :d mja ALS iemand hier goesting in zou ebbe
of als iemand een site zou kenne waar ge da vandaan zou kunne hale
... want pff kzout graag spele
26-11-2004, 20:09 #14
pff kan niemand mij een link fzo geve waar ik die file kan vinden ?
26-11-2004, 20:17 #15
weete wa ge mss ies kunt proberen
eerst uninstalle , dan pc opernieuw opstarten
dan terug de gewone cod installeren , pc opernieuw opstarten
dan de laatste patch installeren , pc terug opernieuw opstarten
en dan united offensive installeren , pc terug opernieuw opstarten
en dan nog ies proberen heno votes
