    scorpionbruno's Avatar
    't Stad van't Peird
    Pacific Fighters patch is uit
    Jawel de eerste patch is er zowel voor de merged als de standalone versie.
    http://www.pacific-fighters.com/en/home.php?skin=S2
    http://www.checksix-fr.com/
    There in the patch we will offer the new method of the program start (new executable programs) We will keep old and new at once - you will be able to compare differences and report us which is the best.
    The size will be ~60 Mb
    And the size for these who like to test new method (new executable module) in additional ~7 Mb
    With the tests here of new module we got better FPS... But the main purpose - to protect from possible in future online cheaters by the new method of code cripting.
    We promised to change the gunnery of the ships - we did it. Even more - it is now more tunable here not only in custom missions, but as well in campaign (both single and online).
    There also is present new map - Marianas. Several new campaigns (and fixes for some of old, where was bugs)
    Fixes and improvemens list? It is simply impossible to list them all. I would say that the changes were applied to more than 200 modules of program where users found the bugs and where we ourselves were making improvements. So we will list just common changes (also not small list of couple pages!) which will include main changes and improvements without list of all the details (or we will write reade one more week )
    So, with the release of this patch we will look for the short respond and then will release add-on with the new planes and dedicated servers.
    En binne 2 a 3 weken nog eentje met nieuwe planes , woehoe !!!
    Zelete's Avatar
    Turnhout
    28 (100%)
    heb hem geïnstalleerd, veel nieuwe mooiere effects moet ik wel zeggen.
    water splashes zijn nice, ook die nieuwe dust is wel goed
    FuLcRuM's Avatar
    Willebroek
    124 (96%)
    eindelijk staan er links bij nice
    Last.fm
    PSN: lennert1984
