    DjProbe's Avatar
    wevelgem
    Probleem bij CMR 5.0 MP Demo
    ellow
    ik hem gelijk een probleemke
    da ding wil nie opstarten ...
    krijg deze error
    iemand die weet hoe ik dit verhelp ?
    thx
    edit :
    extra info
    Geforce 4 440 MX
    drivers zijn van de nieuwste (van Nvidia.com)
    direct X geinstalled
    Windows XP Pro sp I
    Compaq P75 monitor
    AMD 2000+
    Creative Rental Solutions
    http://www.creativerentalsolutions.be
    Scapa Sport's Avatar
    Stabroek | The
    Quote Originally Posted by DjProbe
    welke versie , CMR vereist de 9.0
    GAMES.TELENET.BE - Niet zomaar een gamesite
    Kopieer deze signature en maak kans op een kus van Scapa Sport
    DjProbe's Avatar
    wevelgem
    Quote Originally Posted by Scapa Sport
    uhu 9.0c
    System Information
    Time of this report: 10/6/2004, 18:52:03
    Machine name: LIEVEN
    Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclient.010817-1148)
    Language: Dutch (Regional Setting: Dutch)
    System Manufacturer: n/a
    System Model: n/a
    BIOS: Award Modular BIOS v6.0
    Processor: AMD Athlon(TM) XP 2000+, ~1.7GHz
    Memory: 512MB RAM
    Page File: 232MB used, 1005MB available
    Windows Dir: F:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.0001.0904 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
    Sound Tab 1: No problems found.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: NVIDIA GeForce4 MX 440
    Manufacturer: NVIDIA
    Chip type: GeForce4 MX 440
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_0171&SUBSYS_00000000&REV_A3
    Display Memory: 64.0 MB
    Current Mode: 1152 x 864 (32 bit) (75Hz)
    Monitor: Plug en Play-monitor
    Monitor Max Res: 1600,1200
    Driver Name: nv4_disp.dll
    Driver Version: 6.14.0010.6177 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 7/15/2004 11:42:00, 3740032 bytes
    WHQL Logo'd: No
    WHQL Date Stamp: None
    VDD: n.v.t.
    Mini VDD: nv4_mini.sys
    Mini VDD Date: 7/15/2004 11:42:00, 2459712 bytes
    Device Identifier: {D7B71E3E-4231-11CF-917B-0A2002C2CB35}
    Vendor ID: 0x10DE
    Device ID: 0x0171
    SubSys ID: 0x00000000
    Revision ID: 0x00A3
    Revision ID: 0x00A3
    Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
    Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    Registry: OK
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
