Thread: opstart prob
05-10-2004, 18:23 #1Approved 9-lifer
- 19/02/04
- Ergens ten velde
- 5,712
- 42 (100%)
- 8/51
opstart prob
ik krijg men nieuwe pc aan den donderdag ik instaleer mohaa , wil het spelen , en dan komt er dit :
..GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (8)
...setting mode 8: 1280 1024 FS
...using colorsbits of 16
...calling CDS: ok
...created window@0,0 (1280x1024)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
da komt in console , wa is het probleem en oplossing?Piew piew poewno votes
05-10-2004, 18:26 #2Member
- 20/10/02
- nieuwkerken-waa
- 200
nieuwe drivers voor je vidkaart installen ?
05-10-2004, 18:36 #3Member
- 16/03/04
- Schellebelle
- 137
idd
05-10-2004, 18:41 #4Approved 9-lifer
- 19/02/04
- Ergens ten velde
- 5,712
- 42 (100%)
- 8/51
ok thnx
07-10-2004, 20:56 #5
ja, tis eraan te zien da ge ni Bootmaster heet
07-10-2004, 20:57 #6Member
- 05/12/02
- Ronse
- 2,727
- 9 (91%)
TE droog imo
RaDa [*] RaDa Vs. Lethalno votes
07-10-2004, 22:01 #7Member
- 18/07/02
- Herne
- 6,267
- 0/10
07-10-2004, 22:36 #8no votes
08-10-2004, 01:02 #9no votes
08-10-2004, 02:18 #10Member
- 21/11/03
- Herentals
- 2,118
08-10-2004, 19:23 #11
had da ook is gwn drivers installere :P
