    Drakon's Avatar
    #ind #ind-et
    Server disconnected bij tn
    server disconnected - You have been kicked via Punkbuster (for 0minutes) ... RESTRICTION: Inadequate O/S Privileges
    dit is de boodschap da ik krijg wanneer ik na x-aantal seconde van telenet wordt gekickt, iemand weet hoe dit op te losse, waaraan het ligt?
    Drakon
    Eld0's Avatar
    <*-_-*>
    12 (100%)
    Pas de rechten aan van uw account:
    Is there some way to modify my system configuration to be an administrator equivalent from PunkBuster's perspective in Win2k/XP Pro?
    Yes (under Win XP Pro or Win 2K). This can be accomplished by setting certain privileges for the user that will run the game. To do this, first temporarily log in as an Administrator. Then go to Control Panel => Administrative Tools => Local Security Policy. This will open up the Local Security setting window. Expand the Local Policies folder and select User Rights Assignment. This will bring up a list of security settings for the computer. You will need to add the user that will be launching the game to have the following privileges. If the user is logged in while making changes, the user must be logged out and back in for the changes to take effect.
    • Debug Programs
    • Load and unload device drivers
    • Manage auditing and security log
    • Modify Firmware environment values
    • Profile Single Process
    This is done by double clicking on the setting and then the "Add User or Group" button. You can either type the user or group name into the field or click on advanced to select from a list. If you select advanced, you may need to click on the "Object Types" button and make sure all 3 boxes are checked. Then click "OK". Click on the "Find Now" button to generate a full list of all users and groups on the system. Highlight the user you want to add the rights to and click "OK". Keep clicking "OK" untill you are back at the Local Security Settings window. Repeat this process for the rest of the list. That user will now be able to play on PB servers without getting kicked for "Inadequate O/S Privileges".
    ^Ěld
    Drakon's Avatar
    #ind #ind-et
    k, erg bedankt eldorado om zo vlug een noob uit nood te helpen
    Drakon
    Tongeren
    euhm kan da ook in gewone taal?
    Bizje's Avatar
    Sint-Truiden
    Quote Originally Posted by optio
    Ofwel als admin inloggen, ofwel u een account geven die de nodige rechten heeft.
