Thread: Goldrush 2
    Goldrush 2
    copy past van xfire maar ik zou graag jullie mening hierover willen weten...
    I'm sure many of you agree that Goldrush is and has always been one of the most boring maps in ET. It offers only few tactical possibilities and more often than not ends in a full hold. Lots of suggestions have been brought up to make the map faster but I don't think anyone expected something as radical as bani has come up with:
    Remove the tank, remove the tank barriers, change both axis and allied second spawnpoint location and make the doc run longer. One picture is worthier than 1000 explanations by me so be sure to check out the new command map that reveals the changes.
    By far this would be the biggest gameplay change for ET if the leagues accept it, and I'm sure there'll be a lot of arguing over wether bani should leave ET as it is or not. In my opinion this kind of change would be awesome and just what ET needs. If you look at the command map you should realize how tactical the map would become. I'm sure the document running part would also create some thrilling games since Goldrush provides multiple routes to the objective and you need to cross the axis spawn zone at some point of the trip. Ice anyone?
    You can join the disussion (or flame war) in the ETPro forums here
    - goede zaak volgens mij , map word veel tactisser
    - er waren niet veel goede verbeteringen voorgesteld buiten mss 1 gold crate...
    Your opinion plz
    Jyrki
    pyRomAni@c's Avatar
    HIER
    lol laten we het eerst een weekje proberen dan misschien is het niks
    pyRomaaN
    #hyperion-gaming
    Neerpelt
    goed idee
    .mscr g3un
    AMD64 3200+ || Abit KV8 Pro || 1024MB DDR400 || Asus V9999 GT/TD 256DDR3 || Maxtor 250GB S-ATA/150 || Logitech MX510 || Qpad Midsense || Sennheiser HMD 280 Pro
    WoLfKiLlEr's Avatar
    Mariakerke
    Mja, zou wel nice zijn. Want GoldRush is een van de bekendste mappen in ET dus de meeste kennen zeer goeie tactics enz.. En als je het veranderd moeten ze weer zoeken voor plaatsen dus weer meer fun
    X3M.Lake's Avatar
    Goed idee, maar zie het eerder als een nieuwe map dan een alternatief voor goldrush. Idee op zich ziet er wel leuk uit iig.
    @Bl4st: Ik ben het trouwens oneens met de stelling dat er voor goldrush te weinig alternatieven waren voorgesteld: er is op dit moment zelfs een script beschikbaar dat de 2e tankbarrier weghaalt (wat het enige tijdverlies tss het stelen van de tank en het openen van de bank weghaalt), de bank mg weghaalt (kun je je aanval beginnen zonder de mg eerst te moeten uitschakelen, weer tijdswinst) en je enkel 1 goldcrate moet laten securen (volgens mij nog de minst belangrijke verandering die dat script biedt).
    Bachs's Avatar
    meise
    fuck this, nog maar eens een map gelek radar?
    laat al maar zo
    It's not just a right hand, it's an entire relationship
    Lexirium's Avatar
    Zonhoven
    Niets zo fijn als een objective-run imo.
    Ma zou het tch eerst es moeten spelen,
    ipv zo te beslissen.
    lexy
    Senator's Avatar
    maps veranderen dat gaat tever imo.
    battery is op die manier al verkloot, die map is gewoon van int begin veroordeeld als "geen warmap" zonder dat er iemand deftige tax op geprobeerd heeft.
    maps aanpassen en als "nieuwe map" uitgeven, dat moet wel kunnen.
    Visit Eternal Life warserver at: 82.192.74.195:27960
    IRC: #el.gaming
    eL|Senator
    Cerv.Be's Avatar
    Heist o/d Berg
    267 (100%)
    Eerst proberen, dan beslissen
    Boukreev's Avatar
    76 (100%)
    idd eerst wat testen, maar ziet er leuk uit
    DarkDwarf's Avatar
    The Pie Shop
    Liever die script die Lake heeft voorgesteld dan een alternatieve map.
    Jstr #gravity.et
    meestermongool's Avatar
    melsele
    gold is de home map van mazz en als je wat deftig teamplay hebt enzeo is het aanvallen van die bank totaal nie moeilijk
    gewoon kwestie van spawnkillen en wachten tot er 2-3 van hun de spawn mist
    Xepias
    proud owner of the name MeesterMongool
    eagle_BE_'s Avatar
    melsele-city
    Quote Originally Posted by meestermongool
    idd, grote fun al dat gespawncamp -_-
    Anch's Avatar
    Almere
    Veel te veel veranderingen en niet noodzakelijk. Grootste probleem is "golddefense", daardoor ontstaan de full holds. Een extra route waardoor je achter de bank uitkomt is IMO al genoeg!
    W@CO - visit us at http://waco.somnium.be and #W@CO
    RAINbow's Avatar
    Als die tank er niet meer is voor wat ga je het bovenste gedeelte van de map dan nog gebruiken??
    Kan zijn dat ik iets gemist heb, maar volgens mij gaat er in dat gedeelte niet veel meer gebeuren.
    RAINbow --> aka --> !nst!nct
    lvl 60 orc Shaman --> we come from the orcs we eat (humans) with spoon and forks
    lvl 60 UD Priest (Patchoeli @ xavius)
