Thread: Lagg elke vijf minuten
13-09-2004, 23:21 #1
Het is nu al van in Maart (2004) dat ik in BF1942 elke 5min lagg heb gedurende 10sec. K'eb al verscheidene mails verzonden naar de helpdesk van telenet, maar toen ik de resultaten had verzonden van de ping-tests, kreeg ik geen antwoord meer...
Kdenk niet dat ik te veel programma's op de achtergrond heb draaien en van spyware is er (volgens Spybot en Ad-Aware toch
) geen sprake.
Hijackthis log:
Logfile of HijackThis v1.97.7
Scan saved at 22:16:23, on 13/09/2004
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
D:\WINDOWS\System32\smss.exe
D:\WINDOWS\system32\winlogon.exe
D:\WINDOWS\system32\services.exe
D:\WINDOWS\system32\lsass.exe
D:\WINDOWS\system32\svchost.exe
D:\WINDOWS\System32\svchost.exe
D:\WINDOWS\system32\spoolsv.exe
d:\PROGRA~1\mcafee.com\vso\mcvsrte.exe
D:\PROGRA~1\McAfee.com\PERSON~1\MPFSERVICE.exe
D:\WINDOWS\system32\nvsvc32.exe
d:\PROGRA~1\mcafee.com\vso\mcshield.exe
D:\WINDOWS\Explorer.EXE
D:\PROGRA~1\mcafee.com\agent\mcagent.exe
D:\PROGRA~1\mcafee.com\vso\mcvsshld.exe
D:\PROGRA~1\McAfee.com\PERSON~1\MpfTray.exe
D:\Program Files\D-Tools\daemon.exe
D:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb0 4.exe
D:\PROGRA~1\mcafee.com\vso\mcvsescn.exe
D:\PROGRA~1\McAfee.com\PERSON~1\MpfAgent.exe
D:\PROGRA~1\MOZILL~1\FIREFOX.EXE
D:\DOCUMENTS AND SETTINGS\RAVEN\MIJN DOCUMENTEN\My Downloads\HijackThis.exe
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings,AutoConfigURL = http://pac.telenet.be:8080
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koppelingen
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,Shellnext = http://uk.mcafee.com/apps/mpfplush5/...stempopup=true
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - D:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O3 - Toolbar: McAfee VirusScan - {BA52B914-B692-46c4-B683-905236F6F655} - d:\progra~1\mcafee.com\vso\mcvsshl.dll
O4 - HKLM\..\Run: [MCAgentExe] d:\PROGRA~1\mcafee.com\agent\mcagent.exe
O4 - HKLM\..\Run: [MCUpdateExe] D:\PROGRA~1\mcafee.com\agent\mcupdate.exe
O4 - HKLM\..\Run: [VSOCheckTask] "d:\PROGRA~1\mcafee.com\vso\mcmnhdlr.exe" /checktask
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE D:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE D:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [VirusScan Online] "d:\PROGRA~1\mcafee.com\vso\mcvsshld.exe"
O4 - HKLM\..\Run: [MPFTray] D:\PROGRA~1\McAfee.com\PERSON~1\MpfTray.exe
O4 - HKLM\..\Run: [QuickTime Task] "D:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [DAEMON Tools-1033] "D:\Program Files\D-Tools\daemon.exe" -lang 1033
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] D:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb0 4.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = D:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O8 - Extra context menu item: E&xporteren naar Microsoft Excel - res://D:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: Onderzoek (HKLM)
O16 - DPF: {39B0684F-D7BF-4743-B050-FDC3F48F7E3B} (FilePlanet Download Control Class) - http://www.fileplanet.com/fpdlmgr/ca...C_1_0_0_44.cab
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} (McAfee.com Operating System Class) - http://download.mcafee.com/molbin/sh...3/mcinsctl.cab
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} (DwnldGroupMgr Class) - http://bin.mcafee.com/molbin/shared/...20/mcgdmgr.cabno votes
13-09-2004, 23:34 #2Approved 9-lifer
- Wijnegem
- 2,508
hebbet ook gehad....altijd gedacht da t aan Punkbuster lag
tot maand geleden... plots ultra traag i-net
alles getest op spyware, virussen,....
Enige dat we vonden was dat er packetloss op de lijn zat
(test da zelf misschien eens?)
Dan hebbek gebeld nor Telenet Helpdesk...hebben die tests ivm packetloss nogeens gedaan...
4 dage later (zat een weekend tusse) stond den technieker...noggis getest (heb m zelfs BF laten zien en de ingame lagspikes...van 10 naar 380)...
Mens is nor z'n cammionette gegaan...nief zwart modemke had m bij...oude (moterola cybersurf) vervangen...en hup...sindsdien no more ping probs!!
It's good 2 be the King
---> ---> ---> ---> ---> ---> mobro.co/m4nTiS <--- <--- <--- <--- <--- <---no votes
14-09-2004, 09:39 #3Member
- 10/09/02
- Gent/oudenaarde
- 1,254
- 22 (100%)
same here mantis,
maar het kan ook aan nieuwe drivers liggen, bij mij lag het over 't laatst aan een nieuwe bios die ni goe was.
zet ook uwen outlook express af, diene checkt om de 10 min mssch nr mail en da kan ne pingstoot of ne lag geven.
maar ik denk eerlijk gezegd da mantis er het dichtst bij zit.no votes
24-09-2004, 17:38 #4
Heb nu gebeld met de helpdesk, maar er leek niets mis te zijn met m'n verbinding (packet loss was inorde).
K'eb sinds kort CoD, en daar heb ik geen lagg, of toch niet in die mate (nog maar op 1 server gespeeld, kon dus de server zijn die ietwat lagde
). Dus het moet aan netwerk-code liggen van de BF-reeks (met BF Vietnam heb'k hetzelfde probleem) of iets dat ik veranderd heb in die ene maand. Maar tussen die ene maand en nu zijn al heel wat formats gepasseerd...
24-09-2004, 18:00 #5Member
- 30/08/02
- Harelbeke
- 380
Ik heb da probleem ook, zoveel lag.(=> lagspikes van 4000ms (timeout))
Het ligt hier duidelijk aan de modem, ma telenet scheept mij iedere keer af als ik zou willen vragen om een nieuwe modem te laten zetten.
K'heb al 5 keer gebeld naar hun speciaal nummer en 2 e-mails gestuurd.
Bij het bellen testen ze telkens die modem en zien het probleem (ma zeveren dan over spyware, wat ik niet heb), en k'krijg ni anders dan auto-messages voor m'n mails.
ThnxLast edited by A_BELGIAN_DUDE; 24-09-2004 at 19:10.
24-09-2004, 19:19 #6
ok, heb al gebeld met de helpdesk met de modem uit, en toen bleek ook alles in orde. right. (achteraf bleek er een HW update ergens van TN zelf nodig, packet loss was dan ook opgelost).
Moghelask - Warlock ClassLeader of BABYLON-7 @ Shattered Handno votes
02-10-2004, 18:49 #7
http://users.pandora.be/splinter/Ima...PacketLoss.jpg
Als ik die resultaten bekijk, denk'k nie dat het packteloss is....
