Thread: fps
    steinvancouter's Avatar
    gent
    fps
    hoe zie je je fps
    dibo's Avatar
    Moerbeke-Waas
    typ "fps 1" in je console tijdens het spelen.
    [deleted]
    Guest
    [deleted]
    [deleted]
    rory.b.bellows's Avatar
    duw op " ² " ingame en type " Fps 1 " zet een " Fps 0 " om uit te zetten.
    en als ge fraps wilt gebruiken,draai het op laag formaat en zet uw game setting op 800/600 ofzo voor iets ofwa fps wanneer ge oppakt
    Call me Crazy when you got a good definition of "Normal"
    Jenna Jameson Live action
    "Get in line... Over there!"
    crazyvino's Avatar
    Antwerpen 2000
    domme vraag misschien wat is fps?
    >P>Rushbunny's Avatar
    Antwerp
    Quote Originally Posted by crazyvino
    pronounced as separate letters) Short for frames per second (and typically written in lower case), a measure of how much information is used to store and display motion video. The term applies equally to film video and digital video. Each frame is a still image; displaying frames in quick succession creates the illusion of motion. The more frames per second (fps), the smoother the motion appears. Television in the U.S., for example, is based on the NTSC format, which displays 30 interlaced frames per second (60 fields per second). In general, the minimum fps needed to avoid jerky motion is about 30. Some computer video formats, such as AVI, provide only 15 frames per second.
    AUB
    PS ... Google is zoen gerief hé
    Niet te verwarren met FPS = first person shooter
    Pain is temporary, Glory forever
    Proph3cy
    GT-Rank
    >P>TheBeast's Avatar
    Alken
    FramesPerSeconds en ik dacht dat het over FirstPersonShooters ging gaan
    Lord_Skul's Avatar
    Berchem City
    lol idem beast
    da was ook men eerste gedacht
    Monkey see, Monkey do
    nikeb007's Avatar
    Halle
    frames per second
    PC :
    Asus P8H67 / Core i5 2300k / GEIL 8 GB DDR3-1333 Kit / MSI GTX 660 / Nine Hundred Ultimate Gamer Case / OCZ Modstream 520 watt / DELL U2412M
    The Crazy Noob's Avatar
    Begijnendijk
    Quote Originally Posted by steinvancouter
    hoe zie je je fps
    of als ge die automatisch wilt zien, typ je dit lijntje:
    console.showfps 1
    in je Battlefield Vietnam\Mods\BfVietnam\settings\Profiles\Custom\Ge neralOptions.con
    (zo heb ik het toch gedaan denk ik en het werkt )
    De auteur is niet verantwoordelijk voor de neergetypte letters die toevallig woorden vormen dewelke op hun beurt per toeval zinnen vormen wegens insaniteit.
    Bengie's Avatar
    Haasdonk
    Quote Originally Posted by The Crazy Noob
    console.showfps 1
    goeie tip
    die zet ik op de bengaz site
    svelta olé olé
