    Insano's Avatar
    The Matrix
    [HL2] Nog meer pre-loads op komst!
    Quote Originally Posted by Erik Johnson
    Just to be clear, the cache is 500MB compressed on the wire, which is the number we track closest as it´s the amount of data that will be moved across your internet connection.
    Uncompressed, the files in this preload are around 1GB. For Half-Life 2 to run, they have to be in this state. The first preload event contains most of the textures that Half-Life 2 needs to run.
    This is the first of a number of preload events. We´ll be adding more data to the preload over the next couple of weeks.
    Bron
    Misschien met wat meer hints voor de tweede test
    Bovendien heeft iemand van Valve de vele goud announcements uitgelegd:
    Quote Originally Posted by Chris Bokitch
    There have been several fake "Half-Life 2 Gone Gold!" posts made in forums across the community by people masquerading as Gabe. When Half-Life 2 goes gold, it will be announced via a wide-spread press release. It will be posted many, many places, including the news here and at half-life2.com.
    You'll also hear a collective cheer rise up from the Bellevue area, if you're within a few hundred miles.
    Bron
    "At the beginning of the Portal development process, we sat down as a group to decide what philosopher or school of philosophy our game would be based on. That was followed by about fifteen minutes of silence and then someone mentioned that a lot of people like cake."
    - Valve
    Wid@ker's Avatar
    Heverlee
    Ik install het wel gwn van op de dvd
    Caution is what keeps you out of trouble. Fear is what screws you when caution has failed.
    Tatum's Avatar
    Torhout
    hehehe ik doe de pre load en buy version ( collectors pack verzekers )
    hl²
    elarto's Avatar
    Waregem
    Quote Originally Posted by Captain Insano
    klik
    ga met je muis over de 6de foto, je ziet de gman, klik erop, vul in:
    username: nova
    pass: prospekt
    in het volgende scherm vul je in: barnacle
    en dan geniet je van het resultaat van de 2de test.
    genoeg hints voor je?
    Tatum's Avatar
    Torhout
    waw nice pic, die had ik nog nooit gezien
    hl²
    elarto's Avatar
    Waregem
    Quote Originally Posted by Tatum
    daarom is het ook "the second test"
    ze gaan niemand laten zoeken om dan uiteindelijk een foto te tonen die we al gezien hadden he
    Wid@ker's Avatar
    Heverlee
    Die stond een tijdje geleden op de cover van de PCGameplay.
    le mastre's Avatar
    Waregem
    Uhm dus er zijn van die zieligeaards (n/o ) die zich bezighouden met passwoordjes te zoeken
    maw valve amuseert zich met mensen treiteren
    Insano's Avatar
    The Matrix
    Since there is no 'Congratulations Halflife2.net', some users speculate that the test isn't over. Only time will tell.
    De test is nog niet voor bij he
    - Valve
    elarto's Avatar
    Waregem
    klik hier, voor de mensen die te lui zijn om die dingskes in te vullen
    Insano's Avatar
    The Matrix
    Even uitleg hoe ze hieraan gekomen zijn:^
    At the Half-Life2.com Media Page, it was discovered that the 6th picture changes to the G-Man's face upon mouseover. When you click it it takes you Here.
    After you insert 'nova' as a username, and 'prospekt' as a password you are taken to a Black Page with a text box dominating the middle of the screen. The source of the page has an ascii art of Alyx, with reference to whatsmyname.jpg.
    If you enter the name of that creature(Barnacle) into the text box on the [url=http://www.half-life2.com/secret/secondtest/entry.php]Secret Page^/url], you get to see new art work for Half-Life 2.
    En deze art is al langer bekend, maar niet in zo een detail.
    Het is goed om te zien hoe Valve toch nog de community belangrijk vindt.
    - Valve
    anubiss's Avatar
    Quote Originally Posted by le mastre
    Ik had die link van die citadel gezien in een van de eerste posts over dien 2e test, en het koste mij welgeteld 5 minuutjes om da stukje artwork op mijn scherm te toveren
    (toen ik derna verder scrolde naar beneje zag ik da het antwoord er al lang stond maja)
    Zo erg zijn 5 minute verspilde tijd toch ni he, ge hebt wss zelf eve veel tijd verspild door hier te reply'en
    elarto's Avatar
    Waregem
    Even uitleg hoe ze hieraan gekomen zijn:^En deze art is al langer bekend, maar niet in zo een detail.
    wnr je zo een stuk of 7 posts boven je had gekeken, had je gezien dat je uitleg al gedaan is
    Insano's Avatar
    The Matrix
    Je gaf gewoon de oplossing, niet hoe ze eraan gekomen zijn (met de broncode etc).
    - Valve
    elarto's Avatar
    Waregem
    nm
