    etpro server hosten?
    Mijn vraag is simpel.
    Als je zelf een server host (niet dedicated) is dat automatisch etmain.
    Kan je dat omzetten in etpro?
    Brock's Avatar
    Bristol club -
    Win32: Custom directory
    Find your Enemy Territory directory, usually C:\Program Files\Wolfenstein - Enemy Territory
    Unzip etpro-2_0_1.zip there, it will make an etpro directory and place all the files in the proper paths.
    Start up your server, appending +set fs_game etpro to the command line.
    Linux: Custom directory
    Find your Enemy Territory directory, usually /usr/local/games/enemy-territory
    dit wordt dus maw voor windows:
    "C:\Program Files\Wolfenstein - Enemy Territory\ET.exe" +set fs_game etpro
    BaNoRaC's Avatar
    da moet ge dus in de eigenschappen van uw snelkoppeling zetten
    Quote Originally Posted by Brock
    thx
