Thread: punkbuster
    jagpower's Avatar
    aalst
    punkbuster
    hallo, als ik op de telenet server (1) ga, dan word ik gekickt via punkbuster om de reden :'PB INIT FAILURE', ik heb punkbuster al handmatig geüpdate maar dat hielp niet. kan iemand me helpen?
    greetz
    meestermongool's Avatar
    melsele
    /pb_security 0
    Xepias
    proud owner of the name MeesterMongool
    kzou ook voor de zekerheid een typen /pb_system 1
    en als ge nog eens zo'n problemen hebt lees dan De FAQ
    Jyrki
    jagpower's Avatar
    aalst
    als ik het probleem 'server disconnected for unknown reason' had, hebben ze me dat ook aanbevolen maar het hielp niets, ik zal nu zien of bij dit wel werkt
    Eld0's Avatar
    <*-_-*>
    12 (100%)
    Maybe this helps:
    Why does PunkBuster kick me for INIT FAILURE?
    Usually, this message means your PB is not working properly. You should run our PBWEB program to make sure your PB is up to date.
    However, we have recently discovered that some broadband routers routinely drop OOB (Out of Band) packets for no apparent reason. Since all PB packets are OOB, these routers can actually block PB's communication (again for no apparent reason). To determine if the router is the cause of this problem for you, remove the router and connect directly to the internet. If you are able to play this way, then the cause is very likely the router.
    Based on user feedback, the following router brands/models are reported to have problems. Not necessarily all models of a brand might be affected, and the list is in no way complete but it can give you a few hints. Also, we do not claim that our list below shows the only solution to fix your issue, nor that it will fix it for sure even though it has worked for others. It could very well be that changing some settings in your router could help as well. Contacting the company directly might help you as well.
    Linksys - possible solution: Use firmware 1.44.2
    Motorola - possible solution: Update to latest firmware
    Netgear - possible solution: Disable SPI (statefull packet inspection)
    ^Ěld
