Thread: Punkbuster could not be enabled
18-08-2004, 12:05 #1
Punkbuster could not be enabled.
Dit kwam er bij mij op.
Wat moet ik doen ?no votes
18-08-2004, 12:10 #2
prolly pb nie installed
18-08-2004, 15:07 #3
kijken op 1ste of 3de cd en punkbuster installen, dan activeren en spele
Zwoep Dwarf Hunter - Shattered Hand
Maeron Draenei Priest - Shattered Handno votes
18-08-2004, 16:02 #4[deleted]Guest
[deleted]
[deleted]
19-08-2004, 11:36 #5
Da heb ik gedaan
19-08-2004, 13:42 #6Member
- 04/09/02
- 3,537
- 2/5
Have funHow do I enable PunkBuster?
On the game's Multiplayer screen you will see a PunkBuster checkbox near the bottom, under the list of servers. This checkbox is used to Enable and Disable the PunkBuster client. Alternatively, you can use a text editor to edit the pbclient.con file in the "mods/bfv/settings" folder and change/enter the line: "game.clientPunkBuster 1" (to enable) or "game.clientPunkBuster 0" (to disable). If you edit the file while the game is running, you will need to exit the game and restart for the change to take effect. For Admins running BFV game servers, you need to join the server logged in as a server administrator and use the following console commands (without the quotes): "admin pb_sv_enable" or "admin pb_sv_disable". Alternatively, edit the ServerSettings.con file (or equivalent on your system) usually in the "mods/bfv/settings" folder and use "game.serverPunkBuster 1" or "game.serverPunkBuster 0" respectively.
19-08-2004, 14:19 #7
En als dit allemaal niet helpt
gewoon bfv uninstalle en trug installe dan MET punkbuster.
