Originally Posted by
www.TWRGaming.com
This quote is hidden because you are
ignoring this member.
Show
4. Classes and weapons
Now that you have been connected you need to select a team first, allies (British on some maps) or axis. Here’s a short description of the classes and their features.
Allies
1. Rifleman. You have the M1 Garand, a Colt pistol, a knife and two nades. It’s a great weapon for medium/long range, but you shouldn’t go on a rush with it.
2. Staff Sergeant. You have the M1 Carbine, a Colt pistol, a knife and two nades. It’s a great weapon for short range, as the recoil is much less then on the M1 Garand and it’s got a higher rate of fire.
3. Sergeant. You have a M3A1 Greasegun, a Colt pistol, a knife and one nade. This weapon is designed for close range fighting, but terrible if you want to spray down several enemies at the time, because it does little damage and the rate of fire is quite low.
4. Master Sergeant. You have a M3A1 Thompson, a Colt pistol, a knife and one nade. It’s best to compare this one to the greasegun, because they are usefull in the same situations. It’s got a better rate of fire and does more damage, nevertheless it has more recoil (still not much) and it’s more useful spraying.
5. Sniper. You have a Springfield, a Colt pistol and a knife. As you might have guessed, this is a scoped weapon. You zoom in at the enemy, 1 bullet, and the enemy is dead. You can’t miss a sniper in your team or you are bound to lose.
6. Support Infantry. You have a BAR, a Colt pistol, a knife and one nade. This weapon is useful at any range, as it’s powerful and accurate. It’s also a great weapon in rushes and for a nice spray. Beware, the huge recoil is difficult to get used to when you just start out. But it's possible to deploy the bar as well (just as the machine guns).
7. Machine Gunner. You have a .30 Cal machine gun, a Colt pistol and a knife. This weapon is used whenever you control a certain sport on a map, to keep it. It needs to be deployed to be useful, and if it is, it doesn’t have any recoil and you can simply fire away on whatever is coming for you. But remember this, if you deploy a machine gun, you can’t run away very quickly, so you are quite vulnerable to nades.
8. Bazooke. You have a Bazooka, a Colt pistol and a knife. This weapon is only useful maps where you can open up passages or destroy objectives with it.
Axis
1. Grenadier. You have a Karbiner 98k with a bajonet knife, a Lugas pistol, a knife and two nades. This weapon has great accuracy and does great damage, it’s one of the best weapons in the game. It only has a slow rate of fire and a small clip, which might cause problems in some situations.
2. Stosstruppe. You have a Karbiner 43, a Lugas pistol, a knife and two nades. This is comparable to M1 Garand allies weapon, but I think a kar 98k is far better in the battlefield. This is just not as accurate and doesn’t do as much damage as the kar 98k.
3. Unteroffizier. You have a MP40, A lugas pistol, a knife and one nade. This class is practically the same as the allies sergeant.
4. Sturmtruppe. You have a SG44, a Lugas pistol, a knife and one nade. This is a great weapon for almost any situation. It’s an assault weapon with little recoil, which makes it no problem to shoot over some greater distance.
5. Scharfschütze. You have a Karbiner 98k sniper rifle, a Lugas pistol and a knife. The same as the Allies Sniper.
6. MG’s. You can choose between a MG34 and a MG42, you have a Lugas pistol and a knife. These two are both comparable to the Allies machine gunner. The MG42 though is just raw firepower, as the 34 is somewhat more accurate.
7. Pantzerschreck. It’s the Axis bazooka, you will also have a Lugas pistol and a knife.
British
1. Rifleman. You will have a MK1 Lee Enfield, a Webley pistol, a knife and two nades. It’s one of the most accurate weapons available. If you handle this weapon well, and you aim quickly, you can do great things with this weapon.
2. Sergeant Major. You will have a Sten KM II, a Webley pistol, a knife and one nade. This weapon is a great assault weapon, also because it has very little recoil. It doesn’t do as much damage as the …, but it’s a good one.
3. Marksman. You will have a Enfield sniper, a Webley pistol and a knife. It’s comparable to both the Allies and the Axis sniper weapons, but the flash it gives when you fire this weapon is bigger. It makes it easier for the enemy to know your position.
4. Gunner. You have a Bren machine gun, a Webley pistol, a knife and one nade. It’s does virtually the same as the allies BAR.
5. PIAT. The British bazooka, you will also have a Webley pistol and a knife.
