    Several TO-Crashes :/
    A few weeks ago. I reïnstalled my TO
    After the reïnstall I noticed that my TO didn't worked perfect anymore
    I reïnstalled it a few times (3X) and I always got the same general fault
    I check it with md5:
    "System\IpDrv.dll ERROR: Checksum did not match."
    Now, when I play aot, it always crashes when I enter a map:
    mostly immediatly, but sometimes I got 2 mins game
    When someone sends me his "System\IpDrv.dll" -file I Can play mostly for a long time, but if i restart my TO, it crashes again and again and again...
    I tried a lot things:
    - reïnstalling TO (also in other directories)
    - removing my "user.ini" & "tacticalOps.ini", but still no result...
    - playing with OpenGL
    - replacing my "Ipdrv.dll" by the original "Ipdrv.dll"
    - clearing cache
    - defragmenting my disk
    - installing a TO-version from someone else
    But The same problem appears after 1 game :\
    Might it be possible that TO changes the "Ipdrv.dll" -file during a game?
    I still don't know how to fix it...
    Here's a screenshot: http://www.infinitecreations.be/infinite/crash.JPG
    (from 3 crashes)
    Did someone had the same problem? How do I fix it?
    Quote pls, or pm me @ #-uA (GSurge) or #MCdonalds.to (QNet)
    ps: I'm not allowed to format my hard disk, 'cuz i'm sharing this pc
    Thanks
    -uA.D3F3ND3R
    ps: JAA, mijn engels is niet al te best
    =CID=Drone's Avatar
    Sint-Niklaas
    here is a spoiler : you wil die alone
    nee, ff ernstig , waarschijnlijk zit er in een register nog een oud bestand dat met TO heeft te maken, van een vorige installatie. ff ne register cleaner downloade en da verwijderen.
    aja, tis hier nederlandstalig forum , dus post int nederlands en nie int engels , tis maar een tip dak u geef
    Walther Hagens
    31/10/1947 - 5/4/2006
    Kheb helemaal hetzelfde probleem maar tis lijk maar begonnen als k een week niet gespeeld had
    G-ShOt^'s Avatar
    Ik zou is ne virus scanner laten draaien want die errors zijn meestal de oorzaak van ne virus ergens..
    Impossible is just a big word thrown around by small men who find it easier to live in a world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare. Impossible is potential. Impossible is temporary.
    Impossible is nothing.
    schurno's Avatar
    Sint-Truiden
    Quote Originally Posted by schurno
    ook al gedaan ze...
    en khem zo ne file gevonden die verkeerd/slecht geïnstaleerd was, en alzek die vervangde door die van iemand anders kon ik ff spelen... goeie 2 uur
    Daarna crashed hij terug, echt raar
    Naart schijnt is het fout in TOST ofzo, hebbek dernet nog gelezen, maar dan ist nog nie opgelost hé
    H4ns //'s Avatar
    16 (100%)
    ipdrv.dll van iemand anders met zelfde systeem replacen met de uwe ... tried that one ?
    -_-
    Quote Originally Posted by H4ns //
    spijtig genoeg wel al
    Quote Originally Posted by G-ShOt^
    kzal is checken, want khad overlaatst wel wat wormen
    H4ns //'s Avatar
    16 (100%)
    hmm probeer is gewoon
    instal TO , zonder patch
    try to , gewoon offline
    patch to
    try online
    dan kunde zien of het door tost is eh
    en al geprobeerd met verschillende cd s?
    -_-
    patch to
    try online
    ermz, ben aant scannen nu, al 1 trojan gevonden
    zonder patch zienek et nut ni van in
    maar is offline spelen kan et wel aantonen of et aan tost ligt of ni
    mja, iemand heeft mij cd van TO doorgestuurt, maar kheb hetzelfde voor...
    err0r's Avatar
    Westerlo
    Ne klassieker : format c:
    doe ik ook nogal eens als er iet scheelt
    PsYchO.p2's Avatar
    Sim City
    http://members.lycos.nl/chrispsycho/IpServer.u
    probeert is, dunno oft helpt, ma thielp al iemand anders met crashes
    Computer games don't affect us, I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
    Mijn mixjes staan hier
    WAAAZAAAAA's Avatar
    Quote Originally Posted by ][E®®0R][
    Lees zijn post: hem zegt:
    !!! The only good campers are dead campers !!!
    Proud sletje off B!0$
    Quote Originally Posted by PsYchO.p2
    mercikes, maar kheb net nog ff gespeelt en tblijkt gedaan te zijn...
    Khem zwaar spyware/virussen/trojans/worms liggen deleten (zoals G-Shot vermeld had )
    Net nog ff gespeelt, en het werkte ff...
    Hopelijk blijft et nu werken en crashed et niet gelijk voordien
    Voor allen die help gequote hebben proficiat,
    voor alleen die geen help gequote hebben ook proficiat
