Thread: inadequate O/S privileges
07-07-2004, 21:47 #1Member
- 28/11/02
- Zomergem
- 458
ik krijg dit altijd als error van punkbuster, keb al oplossing gevonden, alleen...kversta ze nie
kan iemand vertaling geven in korte samenvatting?Is there some way to modify my system configuration to be an administrator equivalent from PunkBuster's perspective in Win2k/XP Pro?
Yes (under Win XP Pro or Win 2K). This can be accomplished by setting certain privileges for the user that will run the game. To do this, first temporarily log in as an Administrator. Then go to Control Panel => Administrative Tools => Local Security Policy. This will open up the Local Security setting window. Expand the Local Policies folder and select User Rights Assignment. This will bring up a list of security settings for the computer. You will need to add the user that will be launching the game to have the following privileges. If the user is logged in while making changes, the user must be logged out and back in for the changes to take effect.
Debug Programs
Load and unload device drivers
Manage auditing and security log
Modify Firmware environment values
Profile Single Process
This is done by double clicking on the setting and then the "Add User or Group" button. You can either type the user or group name into the field or click on advanced to select from a list. If you select advanced, you may need to click on the "Object Types" button and make sure all 3 boxes are checked. Then click "OK". Click on the "Find Now" button to generate a full list of all users and groups on the system. Highlight the user you want to add the rights to and click "OK". Keep clicking "OK" untill you are back at the Local Security Settings window. Repeat this process for the rest of the list. That user will now be able to play on PB servers without getting kicked for "Inadequate O/S Privileges".No, please, keep talking. I still have a few brain cells left that you haven't murdered with stupidity.no votes
07-07-2004, 22:01 #2Member
- 04/03/03
- Haasdonk
- 1,927
dit is een uitleg om iemand rechten te geven, zoals een ADMINISTRATOR op een win xp OS.
Maar in meeste gevallen ,zijn we allemaal zelf den administrator op onze computer dus kunne wij wel zonder problemen pb updaten en proggies installeren ,aanpassingen doen.
dus als jij "baas" bent op je eigen computer , moet je je nix van deze uitleg aantrekken.
Zit je echter in een netwerkomgeving en/of ben je geen administrator dan moet je dus aan de beheerder (administrator) vragen of ie je rechten aanpast, en daar is deze uitleg voor
grtz
b.svelta olé oléno votes
07-07-2004, 22:58 #3
volgens mij is hij geen administrator (of heeft em geen administrator rechten)
local administrator dus.
nu, als de "run as" service bolt, zou je jeeventueel tijdelijk admin rechten kunnen geven om de update/install te doen.
zo ben je niet constant ingelogged als admin, wat handig is als er soft installed wordt zonder dat je weet.
je zal nu steevst een pop-up krijgen met de melding "als wie wil je dit installeren ," (niet lettelijke tekst).Last edited by oberon_sedai; 07-07-2004 at 23:01.
Moghelask - Warlock ClassLeader of BABYLON-7 @ Shattered Handno votes
08-07-2004, 11:04 #4Crew Member
- 04/11/03
- Antarctica
- 49,758
- 6 Post(s)
- 1/203
Correct wa Bengie zegt, daar wil ik aan toevoegen dat als ie XP heeft waarschijnlijk inlogd als gebruiker (gast) met beperkte rechten ... inloggen als administrator en eens proberen.
lukt dat wel dan moet ge dus admin rechten toekennen aan uw accountThe Exit is here -------------- Or here www.samexit.be
LEEST ER NU NIEMAND NOG EEN HANDLEIDING???????
veel probs zijn opgelost als men gewoon eens een handleiding zou lezenno votes
08-07-2004, 15:57 #5Member
- 28/11/02
- Zomergem
- 458
tprobleem is dak als beheerder (administrator) ingelogd ben en keb da probleem...
pb is geupdate vie pbweb dus kweet nie waar het probleem zitNo, please, keep talking. I still have a few brain cells left that you haven't murdered with stupidity.no votes
08-07-2004, 17:05 #6Member
- 04/03/03
- Haasdonk
- 1,927
Die quote die jij daar gepost hebt, is da de foutmelding ?
Dus je begint te spelen ,na een tijdje word je gekicked en dan krijg je de foutmelding.
Of is da een mogelijke oplossing die op www.evenbalance.com stond om je PB toch te updaten.
Mijn oplossing :
Ik kan ook ni automatisch updaten , ook ni via die pbweb.exe , prolly ligt dit aan mijn router.
Ik download gewoon die 3 bestandjes (pbsec.htm , waXXXX.htm en wcXXXX.htm) en save die gewoon in de juiste folder.svelta olé oléno votes
08-07-2004, 17:09 #7Member
- 28/11/02
- Zomergem
- 458
die quote is de foutmelding ja, inadequate O/S privileges. ik connect tot server, de map load en als ze volledige geladen is, gaak terug naar da scherm met servers en er staat: kicked by punkbuster (for 0 minutes) blabla inadequate O/S privileges.
et update via pbweb is wel gelukt bij mij, dus daar ligget nie aan denkek...No, please, keep talking. I still have a few brain cells left that you haven't murdered with stupidity.no votes
08-07-2004, 17:14 #8
ik heb aan mijn router niks specaal gedaan voor PB. er staat geen poort extra open of er wordt niets geforward, toch werkt het pb_webudate commando perfect.
