Thread: Client hack 7?
    Kraainem
    Client hack 7?
    Iemand enig idee hoe ik aan dit probleem kom? Telkens ik op een server wil spelen wordt ik gekickt met als message client hack 7. Ik gebruik geen cheats ofzo en een 2 weken terug werkte alles nog perfect.
    Greetz Geert
    DuffMann's Avatar
    #tost @ quakenet
    I dont Know
    nja dan heeft uw broer cheats geinstalled zeker
    nene euhm kijk keer op www.tactical-ops.de ( bij forum van tost bugs )
    greetz
    -=2H@RD2KiLL=-'s Avatar
    Antwerp
    I got kicked for Client Hack 0 what to do?
    this is a bug in B101 Server-Side, when you get this you probably joined an unupdated server, bug the server-admin to update to B104
    I got kicked for Client Hack 2 what to do?
    fastest way to fix this : delete your TacticalOps.ini and let TO generate a new one.
    if that doesnt work try downloading the default ini from here
    I got kicked for Client Hack 3 what to do?
    usually this happens when demo manager/any other external dll is installed, you must uninstall it as top cant diffrentiate it between a cheat.
    I got kicked for Client Hack 5 what to do?
    this usually happens when using an anti-vir such as kasparsky or Bitdefender, make sure none of these are installed.
    only known way to fix this atm is a COMPLETE uninstall of that software. Please check this forum for threads about CH5 and possible sollutions.
    I got kicked for Client Hack 8 what to do?
    this is usually for a locally installed tost, try and search for tost*.u in your TO dir and delete those files.
    I got kicked for Client Hack 9 what to do?
    first you should get the full log of your kick from the server, the description will tell you which file caused the fault, it should be delete.
    also if you have udemo manager, uninstall it.
    vind nix trug van client hack 7, sorry.
    klinkt maybe stom maar defrag eerst eens en install TO opnieuw.
