Thread: bfv tweak guide
27-06-2004, 14:32 #1Member
- 29/07/03
- 1,406
- 0/3
bfv tweak guide
ik was ant surfe opt i-net en ik kwam dezen guide tege dunno of hem ier al heeft gestaan :
CONTENTS
I. Introduction
II. System Requirments
III. The Basics
IV. Video Settings
V. Sound Settings
VI. Advanced Tweaks
VII. Conclusion
I. INTRODUCTION
Hi, and welcome to my BFV tweaking guide. The goal of this guide is to
help people have the best expierience they can while playing BFV.I've found
that many people have quit this game already due to poor system performance.
A new patch isn't always a safe bet either. It can make thingsworse. So I've
come up with some things that can help run this game smoothly and lag free.
They might not work for everybody, but for the most part, if applied
correctly, you'll be able to enjoy this game to the fullest.
II. SYSTEM REQUIREMENTS
***Straight from the box***
MINIMUM REQUIREMENTS
Windows 98/ME/2000/XP
933Mhz PIII or Athlon Processor
256 MB RAM
64mb DirectX9 video card
Directx9 Sound card
2gb hard drive space
16X CD Rom Drive
Cable, DSL or faster
My suggestions to run this game decently are as follows:
Windows XP
2 Ghz Processor
1 gig DDR RAM
128 MB Video Card
They're pretty much the main players in perfomance, and the main things
you need to pay attention to.
III. THE BASICS
***All settings are based on WINDOWS XP***
Many factors contribute to slow down and lag. As the game stands
right now, most of you are not having system problems, you're having
server lag problems. The net code for this game at the momentis horrible.
I get pings of 10 and it still lags. I know its not my computer, because
I'm getting 80-90 FPS while its lagging. This is a server side issue, so
make sure you know if you're lagging or slowing down. You can check your
FPS(Frames Per Second), by opening the CONSOLE. This is achieved by
pressing the TILDE KEY(~`). Its usually next to the 1 key. Once open, type
in FPS 1. Hit enter, then the console key again. You should see your FPS
in the upper left of the screen. To turn it off, repeat the steps above,
but use FPS 0.
Make sure you don't have a lot of programs running in the background.
The most I suggest to be running would be 15. You can check to see how
many you have running by opening up the TASK MANAGER. Press CTRL-ALT-DEL
at the same time to bring this up. Don't just start shutting down things,
as they may be vital to your system stability. I suggest going to Black
Viper's(www.blackviper.com) website. This guy has taken the time to go
thru WIN XP and WIN 2000, to find out what you can safely turn off in the
WINDOWS SERVICES. Follow his directions, and you'll see a huge improvement
in performance.
Don't try to play this game on a 56K. It slows down everything. Not
just for you, but the whole server. I know some people can not get cable
or dsl in their town. Move to somewhere you can get it. Just kidding.
If you can, I suggest getting a second hard drive, and running a
dual-boot system. Install the bare minimum on it. Make it your gaming
system side. Its not very hard to do and it gets the most perfomance out
of your hardware. The OS isn't bogged down by extra, un-needed programs.
Go to www.microsoft.com for tips on running a dual-boot system. Also, if
you can afford it get more RAM. That always helps performance.
Defragment! This is a very important thing to do. Files get spread
all over your hard drive and in turn, degrade the performance of your
machine. Run the windows defragmenting program at least once a week or
after you've installed or un-installed 2 or more programs.
Spy-ware can cripple a system, too. I suggest you get Ad-aware and
Spy-bot. Both have free versions for download. They can remove all adware
and malware from your system. Google for them!
Make sure you have the latest drivers for all your hardware. They
can really be a factor in performance sometimes. Drivers usually fix
performance related issues. I highly recommend this step.
Increasing VIRTUAL MEMORY, or the PAGEFILE size, can sometimes help
out systems with lower amounts of RAM. I've read numerous articles on the
subject, and found that size really does matter. LOL! I suggest making the
size 3 times the amount of RAM that you have installed. So, if you have
256MB of RAM in your system, make your PAGEFILE size 768MB. If you have
at least 1GB of RAM, I wouldn't even worry about this at all, since its
never really a factor. Let Windows manage this or have no PAGEFILE at all.
To access the PAGEFILE, go into the CONTROL PANEL and click on SYSTEM.
Click the ADVANCED tab. Select the PERFORMANCE SETTINGS. Click ADVANCED.
Click CHANGE under VIRTUAL MEMORY. Select CUSTOM SIZE. Plug in the numbers
and click SET. I have another tweak for the PAGEFILE you can find under
the ADVANCED TWEAKS of this guide.
While we're there, CONTROL PANEL, SYSTEM, ADVANCED, PERFORMANCE
SETTINGS, VISUAL EFFECTS. Select ADJUST FOR BEST PERFORMANCE. This can
help some slow moving systems, also.
IV. VIDEO SETTINGS
*Make sure you have the latest patch for the game*
If you're at or slightly above the system requiements, run the game
at low settings. Don't try to run it medium or high. Its going to suck
for you if you do. I run the game at medium and I have a fairly decent
video card. If you have a Radeon 9800 or a GeForce 5950, then you can run
this game at high. Everyone's system is different, so try out
different settings to see what your system can do.
Its not worth it to run this game at 800X600. You miss out on so
many beautiful things. I wouldn't go any lower than 1024X768. You'll
lose maybe 2 FPS. No big deal. Sometimes, it helps to run this game at
a 60Hz refresh rate. I haven't tried it, but some people say it does
wonders. Turn off AA(Antialiasing) and AF(Anisotropic Filtering)
if you don't have a high end system. Especially if you have an ATI
card. EA has stated this themselves.
Sometimes it helps to run in 16 bit mode. Less colors, more
perfomance.
In the video settings uncheck shadows and lightmaps.
You'll get a few more FPS without noticing any degredation in quailty.
V. SOUND SETTINGS
I usually turn the menu music and map loading music off. This is
especially important if you do not have a lot of RAM. It seems to
take up a lot of memory to produce the menu music and map loading
screen music. It definetly helps perfomance to eliminate menu music.
Turn your sound settings to low or medium for a perfomance increase.
Use the least amount of channels that you're comfortable with. I know
I need sound to play this game, so do some expirementing with sound
channels. I'm not sure what OCCLUSION does. It may be what they call
the DOPPLER AFFECT. Like when sound pitch changes depending on the
distance it is to you. Mess with it, and see if you get any changes.
Get the latest drivers for your sound card.
VI. ADVANCED TWEAKS
***Use these settings at your own risk! I claim no responsibility for
any damage done to your system***
First off, make back-ups of all the files we are about to go
over. These are just some .con changes, I have found very useful. I
use them all myself. You can find these all by following this path:
by default C:\Program Files\EA GAMES\Battlefield Vietnam\Mods\
BfVietnam\settings.
This tweak is courtesy of GameFaqs user, APPLE PIE. I give him
all the credit. Open up the DEFAULT.con file with NOTEPAD. By
default it looks like this:
rem *** for BC
Game.GameLevelPath BFVietnam/Levels/Operation_Irving/
Game.useMenu 1
Game.useHud 1
Game.menuMain BattlefieldMenu
Game.menuInGame InGame
Game.menuMap Map
Game.DebugCallbackDisabled 0
run AliasedCommands.con
softRun ../../../Tools/Editors/Editors.con
Make it look like this:
rem *** for BC
Game.useMenu 1
Game.useHud 1
Game.menuMap Map
Game.SoundBufferSize 400
As you can see, I've added the line, Game.SoundBufferSize 400.
This is susposed to make the game not lag. It is said to work,
but I'm not totally convinced. It may or may not work for you. It
doesn't hurt to try it. When you are thru, hit save, not save as.
Open it up again to make sure it saved correctly.
The next trick only works if you turn VERTICAL SYNC off.
There are different ways of turn this off, depending on your video
card. Check the help guides on your system for more information.
Open up the VideoDefault.con file with NOTEPAD. By default it
looks like this:
rem * TEMP *
renderer.FullScreen 1
console.showStats 0
renderer.allowAllRefreshRates 0
console.showStats 0
renderer.allowAllRefreshRates 1
renderer.lockfps 250
Notice I've changed the allowAllRefreshRates to 1 and I
added the line, renderer.lockfps 250. you don't have to put in 250,
but I've found this is the best and most stable number to use.
Make sure you hit save, not save as, and close the file.
If that doesn't help any, you can make the VideoDefault.con
look like this:
renderer.fieldOfView 1
renderer.globalLodRadius 1
renderer.globalLodRadiusScaleFactor 6
console.showStats 0
renderer.useTrilinearFiltering 0
renderer.mipmapbias -3
Sometimes this can lower image quality, but in cases where you
can't get the game to run well at all, try the above settings.
Sometimes fooling with that good old PAGEFILE can solve a lot
of problems. If you're running a dual-boot system, delete it on
the side of WINDOWS that is not running. For instance, if you're
running WINDOWS on your C drive, delete the one on your D drive,
and vice-versa. Make sure you have show hidden files and folders
checked in your folder options, so you can see the PAGEFILE.
Again, if you have a GB or more of RAM, I suggest having no
PAGEFILE at all.
If you don't like deleting things, here's another trick for
clearing the PAGEFILE. Make sure you back up the REGISTRY before
you do this. Type REGEDIT in the RUN box. Navigate to this point:
HKEY_LOCAL_MACHINE\Software\System\CurrentControlS et\Control\
Session Manager\Memory Management
Look for the registry string:
ClearPagefileAtShutdown
Double click it and change the value to 1. Hit OK. Restart
your machine. Now the PAGEFILE will be cleared every time you
shutdown or restart. Now it acts like RAM does, clearing itself,
erasing any bad happenings. I must warn, that this does increase
shutdown and restart times to about 40 seconds on average.
VII. CONCLUSION
BFV is a stellar game that should be enjoyed by everyone
who plays it. EA makes it hard sometimes for us gamers, but
maybe these tweaks will help you out a bit. Thank you for
taking the time to read this guide. If you're in dire need of
help, I'm always availiable at DTAFamily@hotmail.com or
AIM
TAFamily. Once again, if you do have a comment, question,
or suggestion, please feel free to contact me. If you have a
tweak you would like me to add, email it to me and I'll give
you credit for it. Thanks to APPLE PIE for his Sound Buffer
tweak. Thank you EA for an awesome game!!!!! See you on the
battlefield.
©2004 Dominic Cavey/DTA Productions. All rights reserved.
You may not duplicate this document for redistribution without
written consent from Dominic Cavey(MeGaBigD). If you would like
to use this document on your website, please contact
dcavey@comcast.net for permission.emptyno votes
27-06-2004, 15:03 #2Approved 9liver
- 14/11/03
- Sint-Katelijne-Waver
- 2,858
- 10 (100%)
- 3/10
thx
LVL UP! (Discord)
Games.Movies.Funno votes
27-06-2004, 16:12 #3Member
- 01/02/04
- Brugge
- 5,617
- 13/21
er moet gewoon een optie mouse lag in da spel komen .
maar toch effe shecken die guidePC||Antec P182 4x Noctua NF-P12 :: Asus P7P55D LE :: i7 860 @ 4.0 (20x200 Vcore 1.35v IMC 1.40v Scythe Mugen II) :: 4x2gig Corsair Dominator @ 1600 (8-8-8-20 1.6v) :: Asus 5870 @ 930/1250 :: 40gig Bootdisk SSD 500gig workdisk :: Roccat Kave :: Roccat Kone :: Logitech G19no votes
28-06-2004, 18:31 #4
fucking lame tweaks, doe diene brol weg en speelt eerlijk
28-06-2004, 19:17 #5Approved 9liver
- 21/01/04
- Aarschot
- 7,493
- 21 (100%)
- 4/165
dit verhoogt enkel je framerate waardoor je geen pc lag hebt, dit zijn geen hacks.
Sommige mensen toch, he...
Forbidden
You don't have permission to access /forum on this server.no votes
28-06-2004, 19:44 #6Member
- 29/07/03
- 1,406
- 0/3
28-06-2004, 19:52 #7
[qoute]renderer.lockfps 250 [/quote]
mmm 250, ik ken geen enkel systeem dat bf:v op 250 fps runt ...
als iemand de tweak zou volgen, zou ik er 70-50 van maken, afhankelijk van je systeem. moet je een beetje uitzoeken.
ik weet dat ik bf1942 op 60 fps 'locked' speelde.
het zet namelijk je fps vast op een bepaalde rate, als je die te hoog zet, gaat je systeem vastlopen want hij kan het niet aan, als je het te laag zet, gebruik je niet ten volle de potentie van het systeem ...
experimenteren is de boodschap!
om af te sluiten: DEFRAGGEN doet écht wonderen. doet dat ELKE week!no votes
28-06-2004, 19:57 #8Member
- 29/09/02
- Aalst
- 16,414
- 5 (100%)
- 6/1067
Das het leuke aan BF en BF:V: ge kunt het niet zo tweaken zoals games gebaseerd op de Quake-engine, das daar soms echt een pest. In BF/BF:V is het tenminste eerlijk voor iedereen.
___/The Things Network Ghent
28-06-2004, 21:02 #9no votes
01-07-2004, 10:49 #10Member
- 04/03/03
- Haasdonk
- 1,927
nice post sparco
Hoewel ik er ni veel nieuwe dingen in zie die je ook al in BF42 kon gebruiken en vermits dit ongeveer dezelfde engine is ......
toch altijd handig voor de nieuwelingen op dit forum
svelta olé oléno votes
01-07-2004, 13:59 #11Member
- Wilrijk
- 8,061
- 1/48
Veel standaard tweaks maar idd handig voor mensen die er niet zoveel van kennen
en iedreen, for gods sake, zet die menu muziek af
ik bent beu van mensen op Teamspeak te horen dat ze mij niet verstaan door hun maplaadmuziekje
01-07-2004, 18:20 #12Approved 9liver
- 14/11/03
- 2,858
- 10 (100%)
- 3/10
12-07-2004, 16:10 #13Member
- 16/09/02
- 2,211
- 6 (100%)
- 2/2
Ik weet dat dit mss dom klinkt, maar zijn er ook tweaks om battlefield op z'n volle vormogen te laten draaien (er is ooit zo een tweak guide gemaakt voor de demo van ut2003).
13-07-2004, 13:45 #14Member
- 04/03/03
- Haasdonk
- 1,927
13-07-2004, 14:11 #15Member
- 19/03/03
- Galmaarden
- 2,155
- 0/18
kzou toch nog een tweak willen toevoegen die eigenlijk veel leuker is dan al die andere:
rechterklik op de snelkopping van BFVietnam.exe, kies eigenschappen en voeg bij doel ' +restart 1' eraan toe zonder de '
op mijn pc was het dus origineel:
"I:\games\EA GAMES\Battlefield Vietnam\BfVietnam.exe"
en nu is het:
"I:\games\EA GAMES\Battlefield Vietnam\BfVietnam.exe" +restart 1
*edit*
vergeten te zeggen wat het doet, ge moet nie meer wachten bij het opstarten tot al die stomme logo's zijn gepasseerd keer op keer en omdat hij de filmpkes en logo's niet moet laden is u spel direct opgestart zonder lange laadtijden of wat dan ookLast edited by stelly; 13-07-2004 at 14:14.
