Thread: Dcx
26-06-2004, 12:23 #1Approved 9-lifer
- 22/07/03
- Ham
- 932
- 1/1
Dcx
heb net de full version van DesertCombat Extended afgehaald, den 0.72d ofz iet, nu als ik die wil activeren dan cracht het naar menne desktop...
iemand een oplossing?Bmw Powerno votes
26-06-2004, 14:00 #2
DCX derafvegen, k vind da ni zo geslaagde mod
26-06-2004, 14:04 #3Member
- 04/09/02
- 3,537
- 2/5
En dcx heeft wel een paar knappe feature's;I see a .7.1 full and .7.2d patch and then a .7.2d full whats the difference?
In order to play online you must get DCX to version .7.2D, It is your choice if you would like to choose to download 2 files or 1 file in order to accomplish this. Note: People have reported problems with the .7.2d Full installer so it is advised you choose the two file option as it is more likely to work.
http://www.dcxfiles.com/DCX_Pics/Akula-1_Large.jpg
