Thread: cg_setinitialsnapshot
18-06-2004, 22:01 #1
hey
kzen redelijk nieuw in sof en op aandringen van ne maat wa beginne spelen
ma bij sommige servers (bij jolt en gameservers.net al zeker ni) krijg ek een error melding :
cg_setinialsnapshot is an invalid pointer for client
keb al gekeken in FAQ, config al es goed bekeken en google kan er blijkbaar ook niet zoveel informatie over geven dus vraag ek het maar hier° Arguing on the net is like competing in the parolympics : even if you win, you're still a retard
° It's not the one who invents the gun, it's the one who pulls the trigger
° Life is too short to discuss, that's why i'm always rightno votes
18-06-2004, 22:10 #2Member
- 10/06/03
- Ichtegem
- 6,128
- 104 (100%)
- 14/16
dit is wat ik gevonden heb op internet
1)this seems to be a common error ...check through your base and base/mp folder for tmp files and delete them.
when you get the error , leave the game to your desktop then restart the game you will be fine.
2)I think its that ,that server is running a mod of of some kind and you dont have the correct files just turn auto downloads on re-join let it d/l what it needs to then once in the server turn auto d/l's off
3)http://www.orangesmoothie.org/html-beta.html
osp-clientside-0.3d-BETA.zip (337 KB)
(Client side needed for players who will be playing on 0.3 servers, unzip to sof2 folder)
4)http://sof2.ravensoft.com/downloads/wiser2.exe
other then that get and install the OSP mod .. it is now client side no longer server side and you will need it installed to play on servers running the new version of the MODPSN ID: Deletoss Xbox Live ID: D3L3T0Sno votes
