Page 1 of 3 123 Last
    InFerNo's Avatar
    tell
    DDay: Normandy .dll
    DDay: Normandy heeft er weer een nieuwe .DLL bij
    naast America, Germany, Russia en Great Britain is er nu ook Japan om mee te spelen
    To mark the 60th anniversary of D-Day the Japan team add-on is now released.
    Credits:
    Julhelm- Models and skins
    Fafner- Japan code and animations
    EON_MagicMan- Player skins and sounds
    Parts- Japan player model and w_weaps
    Van Wilder- USMC code
    Karr- shouts
    Derrick- icons
    Mappers:
    Mr Your No Fun (kawaj.bsp)
    Eddage (bunk.bsp)
    Fafner (wake.bsp)
    Matthias (map not released yet)
    Gomp (map not released yet)
    This was a great collaborative effort and I think this will be the best team dll yet.
    Here is a link to the zip on fileplanet:
    http://www.fileplanet.com/dl.aspx?/p...ddc/jpn-01.zip
    Here is a direct link to the zip, thanks Shuftie for hosting:
    http://supernova.servequake.com/users/fafner/jpn-01.zip
    Julhelm has a mirror here:
    http://julhelm.dyndns.org:8080/maps/jpn-01.zip
    !nFy has a mirror here:
    http://www.thecript.com/ddaydev/jpn-01.zip
    source code:
    http://www.1rb.mav.net/files/jpn-usm-src.zip
    source code on fileplanet: http://www.fileplanet.com/dl.aspx?/p...pn-usm-src.zip
    This is a test release with only 3 maps. A second release will come later with more maps.
    http://dynamic5.gamespy.com/~ddc/images/jpn1.jpg
    http://dynamic5.gamespy.com/~ddc/images/jpn2.jpg
    http://dynamic5.gamespy.com/~ddc/images/jpn3.jpg
    Diepenbeek
    114 (100%)
    Quote Originally Posted by !nFy
    Ziet er nice uit
    is proberen na de exaams
    InFerNo's Avatar
    tell
    denkt er wel aan, er is geen crosshair en schieten zonder te aimen is bijna onmogelijk...
    ge zult dday op die moment wel lere kenne
    dees is btw een add-on, ge moet dus eerst dday zelve hebbe (en die is zo'n 70Mb dacht ik, ik kan't ni zien want bij mij is die al 2 gig)
    -=BYE=-RiptoR's Avatar
    Anzegem
    Onlangs is de D-Day community edition uitgegeven, met alle addons enzo er al in. File van rond de 500 à 600mb.
    InFerNo's Avatar
    tell
    and how would you know that?
    de Community Edition heeft gewoon alle maps en alle add-ons buiten de nieuwe Japanese .dll
    maar niet alle maps worde gespeeld
    de meeste gespeelde map is DDay2
    Anzegem
    How I knew that? Tis nie omdak onbekend ben in de Quake2 comm, dak da nie weet é
    Heb vroeger veel DDay gespeeld, en ben de DDay ontwikkeling zo wa blijven volgen.
    InFerNo's Avatar
    tell
    lol dday owns your soul ;(
    onder welke naam? and what versions?
    Anzegem
    Altijd onder nick "RiptoR". En vooral versie 4.x.
    Zelete's Avatar
    Turnhout
    28 (100%)
    Ok, ik heb mijn Quake 2 CD eens gezocht en heb hem gevonden samen met een stoflaag van 1 CM dik erop ofzo. Mijn vraag is nu hoe moet ik die MOD fatsoenlijk installeren?
    Ik neem aan:
    - Installeer Quake 2
    - Patch Quake 2
    - Installeer MOD 4.0
    - Installeer patch voor MOD 4.1
    En voor 32-bit Quake 2 hoe moet ik dat doen?
    Anzegem
    Quake2maX zoeken op google, of Quake2 evolution.
    Verwacht wel geen megaverbeterde graphics é
    Zelete's Avatar
    Turnhout
    28 (100%)
    Euhm ik merk hier precies dat ik Quake 2 niet meer kan installeren van de CD?
    Ook compatibility mode werkt niet.
    This version of Quake II will not install on this language version of Windows 95/NT
    (ik heb dus Windows XP Pro Engels)
    Wat nu gedaan?
    Anzegem
    Ge zijt nie den enigsten, maar ken er geen oplossing voor. Bij mij werkt et perfect, bij nen maat nie
    Zelete's Avatar
    Turnhout
    28 (100%)
    Problem solved.
    Gewoon op andere PC installeren en folder overzetten
    Wel raar dat hij op XP Engels niet wil installeren en op XP Nederlands wel
    InFerNo's Avatar
    tell
    DDay is standalone
    ge hebt Quake2 ni nodig
    InFerNo's Avatar
    tell
    Quote Originally Posted by Zelete
    Ik neem aan:
    - Patch Quake 2
    Quake2 heb je niet nodig
    eveneens de patch
    mod moet je niet upgraden, de 4.1 release is serverside
    maar het mag wel
    ik ga mezelf nog ff quoten uit een andere thread
