29-09-2020, 23:18 #601Approved 9liver
- 05/08/02
- Dilbeek
- 14,144
- 17 (100%)
- 175/433
>>> FAQ <<< Xbox Series X | Xbox Series S
Het feit dat het kan is toch gewoon handig?
Ik speel op mijn PS4 nu en dan ook nog PS3-games via PS Now, en zelfs van de current gen zijn er nog talrijke games die ik nog niet heb gespeeld. Als ik daarvan dan improved versions (4k 60fps locked met verminderde laadtijden) kan spelen - en veel daarvan zelfs included in Gamepass, dan is dat dikke value voor mij.
Edit: ben wel niet zeker wat ge bedoelt met die laatste zin? Het gaat in het geval van Xbox toch ook vooral over One-games, met hier en daar een uitzondering (GTA IV van 360)?
Of hoe DF het verwoordt:
In terms of this initial focus on backwards compatibility, I'm sure someone will pop up suggesting that this doesn't really matter for a new console. However, I genuinely believe that this is a poor argument. First of all, the idea of a library of games that stays with you across all the generations is obviously a good thing both for the user and for the idea of preservation in general. Secondly, Xbox Game Pass is so important now and the existing Xbox library plays a key part in that. Finally, while it may be somewhat off-brand to suggest so, I'm not 100 per cent convinced that this generation is anywhere near as tired and decrepit as Xbox 360 and PS3 were at the same point back in 2013 - the enhanced consoles have given a new lease of life to the generation and with titles like Doom Eternal and Modern Warfare 2019, games still look great. Xbox Series X then takes those stunning games and doubles the horsepower available to them, while comprehensively addressing the poor CPU performance of the current gen era. Put simply: Microsoft is right, your games can look better and run more smoothly - and that's before we factor in the power of the SSD.Last edited by Shyheim; 30-09-2020 at 00:08.
29-09-2020, 23:46 #602Member
- 06/02/04
- Leuven
- 1,534
- 18 (100%)
- 2 Post(s)
- 33/47
Wat is er niet juist van wat ik gezegd heb? In het DF filmpje zelf zeggen ze dat ze hun daarop gefocussed hebben om een benadering te kunnen maken van het verschil in kracht tussen de 2 generaties. Dus op die selectie games werkt dat zo.
Ook zeggen ze dat als er een framerate cap is (wat in 90% van de gevallen zo) je buiten een meer stabielere framerate niet opeens naar 60fps gaat gaan. Als er geen dynamische resolutie is, zal er ook niet opeens een hogere resolutie beschikbaar zijn. Dit is enkel later mogelijk als de ontwikkelaar of MS de game patched.'If you're not sure what to do with the ball, just pop it in the net and we'll discuss your options afterwards.' Bill Shankly. LFC YNWA!no votes
30-09-2020, 00:18 #603Approved 9liver
- 05/08/02
- Dilbeek
- 14,144
- 17 (100%)
- 175/433
Denk dat uw 2 punten toch besproken worden in DF-artikel:
Die performance cap zit hem toch vooral op games als The Last Jedi (om er 1 te noemen) waarbij ge capped 30 FPS krijgt om 4k te kunnen spelen?But we shouldn't expect Series X to act as a 60fps saviour for all games. While Microsoft's compatibility team has a track record in delivering technical miracles - and is talking about 4K versions of 1080p Xbox One S games and double frame-rate modes - by default, if a game has a 30fps performance cap, 30fps is the best you're going to get.
Heb mijn eigen quote net herlezen trouwens - was niet aanvallend bedoeld al lees ik het nu zelf ook zo
30-09-2020, 10:13 #604Member
- 24/03/15
- Beersel
- 652
- 4/76
Zelf nog aan het twijfelen tussen een XSX of een XSS. Gezien ik nog een redelijk oude LED-tv heb die geen 4K support en ik niet direct een nieuwe tv zal aankopen, is het dan de meerprijs waard om een X te kopen? De prijs van PS5 games en de gamepass bij Xbox hebben me doen kantelen naar Xbox, nu is het enkel nog kiezen tussen beide consoles
de prijs speelt uiteraard ook mee.
30-09-2020, 10:15 #605Member
- 06/10/02
- Lovendegem
- 2,683
- 48 (100%)
- 14/15
Alienware Area51m - Ps4 Pro - Nintendo Switch - PS5 - X-BOX Serie X -no votes
30-09-2020, 10:20 #606Member
- 06/02/04
- Leuven
- 1,534
- 18 (100%)
- 2 Post(s)
- 33/47
Performance cap zit op vrij veel spellen
een framerate die van 25 tot 40-50 gaat is heel onaangenaam dus op de meeste spellen is een cap van 30 gezet om stabiliteit te garanderen. Dit is natuurlijk voor games die geen 60fps targetten.
Ja was toch een beetje zo
30-09-2020, 12:00 #607Approved 9liver
- 21/08/02
- Lokeren
- 5,926
- 153 (98%)
- 2 Post(s)
- 41/66
Xbox Live: kTs Yonesno votes
30-09-2020, 13:19 #608Member
- 04/06/13
- Beveren
- 1,253
- 5 (100%)
- 3 Post(s)
- 3/79
Beter nu €200 extra neertellen dan binnen 3 jaar nog eens €500 (give or take) te betalen omdat u oude tv het begeven heeft waardoor je plots toch 4K kan spelen.
Uiteindelijk is die €200 snel terugverdient door enkele games die niet in de gamepass steken 2ehands op disc te kunnen aankopen.
Tenzij er rond 2023 een "Pro" model uitkomt natuurlijk, dan kan je die eerste jaren perfect overbruggen met een S als je het verschil toch niet ziet door u TV.no votes
30-09-2020, 13:22 #609Approved 9liver
- 21/11/04
- Brussel
- 7,840
- 97 (100%)
- 14/44
Ik vraag mij vooral af hoe future proof die Series S is. Ik overweeg hem als tweede console naast mijn PS5 (heb ook nog €100 tegoedbon, dus zou mij maar €199 kosten). Maar gaat die binnen 4-5 jaar de nieuwe releases nog altijd even vlot kunnen draaien? Die zwakkere processor speelt mij dus vooral parten.
Laten we hopen dat die Series V geruchten waar zijn en dat die voor een mooi prijsje zal verkocht worden. Dan zou de keuze rap gemaakt zijn.Tasta.me - Zoekt extra reviewers voor PS4, Xbox One en PC!PSN/XBL: FreakyJPno votes
30-09-2020, 13:45 #610Approved 9liver
- 07/06/04
- Genk
- 9,401
- 15 (100%)
- 18/26
Ik ben voor de series S gegaan. Heb geen 4K tv of receiver en mijn bedoeling is dit vooral voor gamepass te gebruiken en een ps5 als “main” console aankopen eens de echte kleppers van exclusives beginnen te komen
Over futureproof ben ik ook niet zeker, al zeggen de meeste wel van presteert gelijkwaardig als de X ma dan zonder 4K.. ben benieuwd of het waar is..Stadia: YogiBear PSN: YogiBear087 XBox Gamertag: YogiBear087Switch FC: SW-0043-9004-9251 (Yogi)no votes
30-09-2020, 16:41 #611Member
- 03/01/04
- BEVEREN
- 14,174
- 371 (100%)
- 2 Post(s)
- 16/30
Ge kunt hem nogaltijd preorderen. Kzou er nie van verschieten dat ze de S zouden droppen binnen een paar jaar
...no votes
30-09-2020, 16:49 #612Member
- 29/01/19
- 446
- 4 Post(s)
- 3/23
Bij de PS5 versies heb je buiten de disc drive op vlak van hardware geen verschil. Maar als ik het goed begrijp is er tussen de Series x en Series s, buiten de ontbrekende discdrive, wel een verschil op vlak van hardware?
30-09-2020, 16:55 #613Member
- 05/09/10
- Zelzate
- 18,906
- 155 (98%)
- 48/153
30-09-2020, 17:23 #614Platinum Member
- 01/08/04
- De K.
- 29,744
- 51 (100%)
- 11 Post(s)
- 189/826
30-09-2020, 18:17 #615Approved 9liver
- 01/05/14
- FarAway
- 6,043
- 3 Post(s)
- 54/287
Is heel dat memmen op die series s nu nog bezig
Die console is gewoon gebouwd naar het punt waarop die moet werken , 1080 of 1440p 60 FPS.
Als jij een 1080p pc in elkaar steekt ga je dan ook voor een rtx 3080 met ryzen 7 3700x en 32gb ram ? Nee.
Ja er is verschil in hardware tussen beide maar dat is omdat de ene appelen moet draaien en de andere peren.
Als je al op voorhand issues hebt dat je niet dezelfde specs krijgt gooi dan gewoon 499 ipv 299 op tafel ook al zit je op een 1080 of 1440p scherm en klaar is Kees met je “probleem”
Hierboven spreekt ook iemand over een zwakkere cpu, het verschil is 100 of 200mhz.... op een pc cpu zou je dat een verschil van nog geen 5% geven in performance...
