    [BE]TETTENMAN's schermafbeelding
    13/11/15
    BRUGGE
    6
    Project Alderaan - Parallel loop build
    Hello Fellow modders,
    Been doing pc building for a couple of years. Started with a small cpu soft tube loop in an antec 900 case. Since then i build several ones in a 570 x case. Reason for this case, is that is gives a lot of opportunities for custom loop builds. The negative side is that this case can be a pain in the *** for cable management if you have lots of components with wires.
    However the case itself looks magnificent on its own. Next one will probably be a lian li case.
    So where do I start. I've seen some couple of builds with a parallel loop going from cpu to gpu and back, however lots of ppl were concerned about the airflow and temps in that kind of loop. Out of curiosity, I wanted to try out a build with this kind of loop.
    It is very important to sketch your loop, to see how the flow will work and to choose a good and strong pump for this. Also good clean bending lets you have a good flow rate. Bends that got too hot and are abrupted can cause a lower flow rate.
    It took me about 30 hours of work, to get the bends and the build to work great. I had to do little adjustments to some bends and work with the pump cuz in the beginning the flow rate was too low and the cpu block couldn't fill it self up. However after these adjustments, the flow rate worked like a charm, filling up all the blocks and releasing all the air out of the loop.
    Temps of the water:
    - Idle between 20 and 25 - load between 30 and 35 All this depends on the room temperature, weather and fan speed.
    Temps of the blocks: 1) CPU - idle between 20 and 25 - load between 40 and 45
    2) GPU - idle between 20 and 25 - load between 30 and 35
    As you can see these are really great temps.
    So this concludes also that building a parallel loop does not disadvantage your flow rate and temps if you do it right.
    The case also comes with adjustable led lights and hd 120 fans so every colour scheme is possible. Included are 2 60 cm cablemod dual led strips. With dual I mean, one side has rgb colours, the other side has UV lights. The coolant used is cfx opaque ghost white with a sky blue uv additive.
    Adjusting your colourscheme will also light up the liquid.
    Watercooling components: EK CPU block bitspower gpublock EK xtop REVO D pump bitspower drain valve bitspower and ek fittings xpsc lyquid temp sensor EK 250 lite white reservoir hardware labs 240 and 360 gts radiators
    Enjoy the pics. Feel free to give me feedback and respond with your opinion.
    PS: tekst in het engels omdat ik deze gekopieerd heb uit partpicker voor mijn build. Desondanks denk ik dat iedereen dit wel zal verstaan.
    [IMG]]https://cdn.pcpartpicker.com/static/forever/images/userbuild/225713.3bd0d417027a9b8f18c269eeb3a2ce36.1600.jpg[/IMG]
    PC Modding Belgium
    instagram id: @pcmodding_belgium
    facebook: https://www.facebook.com/PCModdingBelgium/
    gunnie's schermafbeelding
    Turnhout
    4.978
    86 (100%)
    Leuk dat je het post maar ik zou het toch graag in het Nederlands zien, we zijn een Vlaams forum tenslotte.
    Muscleduck's schermafbeelding
    27/11/03
    12.468
    Kraantje onderaan is slim gezien! Propere build.
    Raptr | Steam | PSN | Last.FM | Mobile Vikings | Generation Connect | Duty Calculator | Spam
    i5 2500K | 16 GB Kingston HyperX | 590 GTX
    [HBV]-=Tornado=-'s schermafbeelding
    Gijzegem
    1.635
    41 (100%)
    Mooi gedaan!
    9/11/14
    thuis
    515
    Nice well done , mooi leuk gedaan lol
Inloggen
Inloggen
