11-01-2017, 23:03 #1
Stroomtang/multimeter true-rms Iso-Tech ICM133R
Slechts 1x gebruikt.
- ICM133R 1000A ac,True-rms reading
- 1000A ac current measurement
- 750Vac / 1000Vdc voltage measurement
- Large 51mm dia. conductor jaw capacity
- 4000 count backlit digital display with analogue bargraph
- True RMS reading on AC mode
- Resistance & continuity beeper <30Ω
- Display Hold & Min Max Function
- 10ms Peak Hold on ac A & ac V
- Frequency Counter
- Auto Power Off (30 minutes)
- Separate battery compartment
- 600V circuit protection
- Complies with EN61010 CAT. III 600V Safety Standard for industrial applications
- Rugged construction with flame retardant, high impact plastic
- ac voltage
- Ranges 400V & 750V
- Resolution 0.1V & 1V
- Basic Accuracy ±(1.0% rdg+ 5d)
- 50 to 500Hz
- dc voltage
- Ranges 400V & 1000V
- Basic Accuracy ±(0.7% rdg+ 2d)
- ac current
- Ranges 400A & 1000A
- Resolution 0.1A & 1A
- Basic Accuracy ±(1.9% rdg + 5d) 50-60Hz
- Resistance
- Range 400Ω
- Resolution 0.1Ω
- Basic Accuracy ±(1.0% rdg+ 3d)
- Frequency counter
- Ranges 4kHz & 10kHz
- Resolution 1Hz & 10Hz
- Basic Accuracy ±(0.1% + 2d) @5V rms max
- Size (WxHxD) and Weight 90 x 275 x 51mm, 420g
- Supplied with
- Test leads, carry case, instruction leaflet and 9V PP3 alkaline battery.
Specs: ICM133R Clampmeter, Max Current 1000A ac CAT III 600 V purchased inexpensively from Mercateo
Bieden vanaf 30 euro excl.
Verzending via Bpost.
Winnaar is bekend, 72u na hoogste bod.
Cheers,
Shiseido
13-01-2017, 21:58 #2Member
- 18/02/07
- Leuven
- 139
- 14 (100%)
Locatie "L" ... waar is dat exact?
14-01-2017, 09:47 #3
Net voorbij het gazettenpapier
, Lier
Sent from my iPhone using Tapatalk Pro
14-01-2017, 10:02 #4Member
- 17/10/03
- Meulebeke
- 19,946
- 33 (100%)
- 19 Post(s)
- 0/378
bod van 30€ excl.
14-01-2017, 13:13 #5
Genoteerd!
17-01-2017, 20:52 #6Member
- 17/10/03
- Meulebeke
- 19,946
- 33 (100%)
- 19 Post(s)
- 0/378
72u zijn voorbij denk ik?
18-01-2017, 12:06 #7
PM komt eraan!
