Page 1 of 3 123 Last
    Sint-Niklaas
    Leeyuentuen Kamer opruim deel1 UPDATED 2
    CPU
    (1) Intel E8400 Socket 775 (3.0Ghz) min 20, meeneem 35
    (2) AMD Athlon 64 3500+ Socket 939 min 15, meeneem 30
    (3) Intel Pentium 4 1.60 GHz, 512K Cache, 400 MHz FSB socket 478 min 5, meeneem ?
    Grafische kaart:
    (4) Asus EAH 3850 512MB min 30, meeneem 40
    (5) EN6600td 256mb pci-e (defect) zonder cooler/heatsink min 1, meeneem ?
    (6) Geforce FX-5200 128mb agp (defect) zonder cooler/heatsink min 1, meeneem ?
    (7) Hercules 3D prophet II MX agp min 10, meeneem 20
    Combo:
    (8) Asus M2N-sli Deluxe // AMD Athlon64 4600+ socket AM2// Arctic Freezer 64 min 25, meeneem 40
    HDD:
    (9) Seagate Certified Repaired HDD 750GB 3,5" (S/N:9QK1SB30 P/N:9BX156-303, garantie tot 28 nov 2013) min 35, meeneem 50)
    RAM:
    (10) 2x128mb edo mde128M01JD sdram min 2, meeneem ?
    (11) 256 sdram pc133 min 1, meeneem ?
    (12) 512MB Siemens DDR PC2700 min 5, meeneem ?
    (13) 512MB Hynix DDR 400mhz cl3 min 5, meeneem ?
    (14) Twinmos 1GB DDR2 677mhz min 7, meeneem ?
    (15) 2x2GB Hynix So-dimm DDR3 PC8500 HMT125S6AFP8C (Kom van macbook pro) min 25, meeneem 35
    (15b) 2x2GB Hynix So-dimm DDR3 PC6400 HMP125S6EFR8C Min 20
    (16) 2x1GB Hynix So-dimm DDR3 PC8500 HMT112S6AFR6C (Kom van macbook pro) min 20, meeneem 30
    (17) 256MB DDR So-dimm Samsung PC3200 M470L3223ET0 min 5, meeneem ?
    PCI-Kaarten
    (18) creative labs CT4810 soundcard PCI min 5, meeneem ?
    (19) PCI soundcard CMI 8738 6CH min 5, meeneem ?
    (20) 3com etherlink XL PCI 3c900B-TPO Ethernet card min 5, meeneem ?
    (21) LevelOne RTL84139C Ethernet card min 7, meeneem ?
    (22) domilus 1 ext-sata, 2 int SATA, 1 IDE controller VT6421A min 5, meeneem ?
    (23) Tenda Wireless Lan PCI Adapter TWL108P min 7, meeneem ?
    (24) BroMax WM606-BF mini-pci wifi kaart min 5, meeneem ?
    overige
    (25) Corsair Dominator Cooler min 5, meeneem ?
    (26) Zalman GPU cooler VF7000 min 5, meeneem ?
    (27) Combo: Mobo (PGA370) + Celeron 633mhz + 256MB ram min ? meeneem ?
    https://dl.dropboxusercontent.com/u/...6/DSC_2078.JPG
    (28) Combo: Mobo + Celeron 400mhz + ram (hym7v64400 + 2x mt16LSDT464AG ==> 96mb ram?) LET OP: CPU heeft geen koeling aanwezig!!!!! min ? meeneem ?
    https://dl.dropboxusercontent.com/u/...6/DSC_2079.JPG
    (29) Combo: Aopen ax4spe-n + P4 2.60 + msi 8999 AGP + 2x1GB Corsair Valueram min: 20 meeneem ?
    https://dl.dropboxusercontent.com/u/...6/DSC_2080.JPG
    (30) OCZ PC3200 OCZ4002048ELDCPE-K 2x1GB Ram 2-3-2 @2.8v (lifetime warrenty?) min 20 meeneem ?
    Foto's
    https://dl.dropboxusercontent.com/u/...p/DSC_1859.JPG
    https://dl.dropboxusercontent.com/u/...p/DSC_1860.JPG
    https://dl.dropboxusercontent.com/u/...p/DSC_1861.JPG
    https://dl.dropboxusercontent.com/u/...p/DSC_1862.JPG
    https://dl.dropboxusercontent.com/u/...p/DSC_1864.JPG
    https://dl.dropboxusercontent.com/u/...p/DSC_1865.JPG
    Regels:
    - Eens het minimumprijs gehaald wordt, wordt het afgesloten na 24uur na het laatste genoteerde bod tenzij men de meeneemprijs bied
    - bieden per minimum 1 euro
    - Bieden = Kopen!!
    Sint-Niklaas
    Hoogste bieding:
    (1): dnanarcoticz 20 euro afsluitdatum 6 april om 20u
    (2): -
    (3): -
    (4): babse 30 euro verkocht
    (5): -
    (6): -
    (7): babse 5 euro verkocht
    (8): apart verkopen (nieuwe thread starten)
    (9): -
    (10): -
    (11): -
    (12): -
    (13): -
    (14): -
    (15): apart verkopen (nieuwe thread starten)
    (16): apart verkopen (nieuwe thread starten)
    (17): -
    (18): -
    (19): -
    (20): -
    (21): -
    (22): -
    (23): -
    (24): -
    (25): -
    (26): -
    (27): -
    (28): -
    (29): apart verkopen (nieuwe thread starten)
    (30): apart verkopen (nieuwe thread starten)
    Sint-Niklaas
    lijst update en extra te koop.
    Teemto's Avatar
    Duffel
    175 (100%)
    20€ excl op HD3850
    Shrimp boat deckhand http://www.madshrimps.be/
    That's Jeff Vader that is. I'm not Jeff Vader, I'm Darth Vader. What? Jeff Vader who runs the Death Star? No I run the Death Star. You Jeff Vader? No, I'm Darth Vader! You his brother? Can you get his autograph?
    Sint-Niklaas
    Quote Originally Posted by Teemto View Post
    20€ excl op HD3850
    Zou toch wel min 30 willen
    Sent from my iPhone using Tapatalk - now Free
    Sint-Niklaas
    Upke1
    edit: Vanaf nu te koop op 2de hands wegens te weinig interesse hier.
    Sint-Niklaas
    upke, bij meerdere objecten zijn de prijzen bespreekbaar.
    Buggenhout
    €60 exclusief
    Sint-Niklaas
    Quote Originally Posted by babse View Post
    €60 exclusief
    Genoteerd
    Laat ons zeggen afsluitdatum voor deze pakket op 5 dec om 12:12 indien niemand hoger pakket bieding heeft van 60 euro.
    Sint-Niklaas
    extra toevoeging:
    Buggenhout
    Wegens aankoop ander systeem hier, aanpassing van mijn aanbod:
    (4) €25
    (23) €5
    exclusief uiteraard
    Sint-Niklaas
    (4) €25
    (7) €5
    exclusief uiteraard
    normaal boden dat genoteerd zijn niet te wijzigen. Ik wil dan wel door de vingers zien indien je voor bovenstaande pakket (4) en (7) samen neemt voor de prijs van 35 euro exclusief.
    Buggenhout
    Bij deze:
    (4) €30
    (23) €5
    Sint-Niklaas
    Bij deze:
    (4) €30
    (7) €5
    hierbij genoteerd, de voorgaande bod zijn dan genegeerd.
    hierbij ga ik afsluiten op donderdag om 17u
    kibo's Avatar
    Beveren
    144 (100%)
    Een bod kan je in principe niet wijzigen(bieden is kopen),maar blijkbaar hebben jullie al een oplossing gevonden.Dus probleem opgelost.
