    Golla's Avatar
    Vl Brabant
    Scythe Mugen 2 Rev. B SCMG-2100 CPU Koeler
    Wegens een upgrade naar waterkoeling mag deze prachtige CPU koeler de deur uit.
    Dit is één van de beste lucht CPU koelers die er gemaakt zijn, koelt zeer goed en is lekker stil..
    Wat info en specs :
    Scythe Mugen 2 Rev. B CPU cooler is the consistent further development of the award-winning Mugen CPU cooler. Several features make this cooler the perfect solution for silent users and overclockers! New Rev. B is equipped with advanced back-plate to simplify mounting as well as providing socket LGA 1556 compatibility. Mugen 2 is on the latest state of technology and was produced using highest Japanese quality standards.
    Features
    F.M.S.B. (Flip Mount Super Back-Plate)
    The newly developed F.M.S.B. (Flip Mount Super Back-Plate) both improves the compatibility and mounting of the cooler with the motherboard. With this system, a solution was developed which is not using push pins but is instead based on a Back Plate/screws mounting set. Of course, Mugen 2 Rev. B is compatible with all the current sockets, including the new Intel Socket LGA 1156 and LGA 1366.
    Multi Fan Mount Structure
    As with the former Mugen it is possible to mount the supplied fan in four different directions. By this, the user can arrange the air flow to the circumstances of his deployment area. Furthermore, a maximum of 4 fans be installed, the needed fan clips have to be bought separately.
    M.A.P.S. (Multiple Airflow Pass-Through Structure)
    The newly developed M.A.P.S. (Multiple Airflow pass-through structure) is a completely new fin structure, where the airflow generated by the Scythe Slip Stream 120 mm PWM fan can be used perfectly
    Specifications
    Model Name: Mugen 2 Rev. B CPU Cooler
    Model No.:SCMG-2100
    Compatibility:
    Intel®:
    Socket 478
    Socket T / LGA775
    Socket LGA1155
    Socket LGA1156
    Socket LGA1366
    AMD®:
    Socket 754
    Socket 939
    Socket AM2
    Socket AM2+
    Socket AM3
    Socket AM3+
    Socket FM1
    Socket 940
    Combined Dimensions: 130 x 100 x 158 mm / 5.12 x 3.94 x 6.22 in
    Fan Dimensions: 120 x 120 x 25 mm / 4.72 x 4.72 x 25 in
    Noise Level: 0 - 26.50 dBA
    Air Flow: 0 - 74.25 CFM = 0 - 126 m³/h
    Fan Speed: 0(+200 rpm) - 1,300 rpm(±10%)
    Weight: 870 g / 30.69 oz
    Material of Base Plate: Nickel-plated copper
    More info & reviews:
    Mugen 2 Rev. B: CPU Kühler, Lüfter, Lüftersteuerung, PC Netzteile von Scythe
    Mijn vaste vraagprijs is 25€
    Afhaling te Tienen, tegen kleine meerprijs leverbaar omgeving Sint Truiden , Leuven , Bekkevoort , Tielt-Winge.
    2 foto's van mijn kant :
    http://i47.tinypic.com/1fft3o.jpg
    http://i49.tinypic.com/29mrd3s.jpg
    Staat ook op Tones forum te koop.
    Liquid_Ninja's Avatar
    Bornem
    116 (97%)
    Zit alles erbij, en heeft deze nog koelpasta over?
    Bod van 25 incl. verz.
    Golla's Avatar
    Vl Brabant
    Alles zit erbij behalve koelpasta.
    29€ incl verzending en we hebben een deal, moet nog een doos kopen van bpost en de cpublock is ook niet bepaald zo licht.
    Golla's Avatar
    Vl Brabant
    Deze fantastische cpucooler is nog steeds beschikbaar
    Brugge/knokke
    50 (100%)
    29incl.
    Golla's Avatar
    Vl Brabant
    Deal JayBrown!
    Check pm
    Golla's Avatar
    Vl Brabant
    Afgehandeld. Mag toe.
