25-04-2011, 15:48 #1
ventilators (gebruikt en nieuw) verschillende merken
Coolermaster Neon LED Fan 120x120mm (blauw) (zat in Coolermaster Stacker 832SE, enkele dagen gebruikt)
Dimension (W / H / D) 120x120x25 mm
Voltage 12 VDC
Current (Ampere) 0.15 A
Input (Watt) 1.80 W
Speed (R.P.M.) 1220 R.P.M.±10%
Air Flow (CFM) 42.734 CFM
Air pressure (mmH2O) 1.557 mmH2O
Fan Noise Level (dB-A) 22 dB-A
Weight 137g
Bearing Type Sleeve
Fan Life Expectancy 30,000 hours
Speed sensor Yes
LED number 4
foto:
[IMG]
[/IMG]
productpagina
Coolermaster UV Silent Fan 120x120mm (Twee weken gebruikt)
Dimension (W / H / D) 120x120x25mm
Voltage 12 VDC
Current (Ampere) 0.04A (Max 0.06A)
Input (Watt) 0.60W
Air Flow (CFM) 42.73 CFM
Air pressure (mmH2O) 1.56 mmH2O
Weight 120 g
Bearing Type Sleeve
Speed sensor Yes
productpagina
foto's met uv lichten aan (in behuizing)
[IMG]
[/IMG]
uv lichten in behuizing uit:
[IMG]
[/IMG]
de ventilator :
[IMG]
[/IMG]
Coolermaster Silent Fan 120 SI2 (zat bij cm stacker 832SE, enkele dagen gebruikt)
Dimension (W / H / D) 120*120*25mm
Voltage 12VDC
Current (Ampere) 0.15A
Input (Watt) 1.8W
Speed (R.P.M.) 1200 R.P.M.±10%
Air Flow (CFM) 44.73CFM
Air pressure (mmH2O) 1.65 mmH2O
Fan Noise Level (dB-A) 19.1 dB-A
Weight 120 g
Available Color black
Bearing Type Sleeve
Connector 3 pin
foto:
[IMG]
[/IMG]
productpagina
VIZO STARLET UV LED Fan ( Ultra quiet / Ultra bright ) (1week gebruikt)
Vizo presents Starlet UV LED fan to tweak your PC. Lite it up with an assortment of vibrant colors.
FEATURE
Built-in ultra bright UV LED Lights.
Stylish UV light sensitive fan.
specs
Fan Size : 120x120x25 mm
Rated Voltage : 12 V
Rated Current : 0.17 A
Fan Speed : 1300 RPM
Air Flow: 49.33 CFM
Noise: 24.9 dBA
Weight : 128 gm
Bearing Type : Sleeve
UV Green (met uv lichtjes)
foto:
[IMG]
[/IMG]
3* Scythe Slip Stream 1900 rpm (120mm) (2 weken gebruikt)
37,00 dBA / 110,31 CFM = 187 m³/h / DC12 V / 0,53 A (1,900 rpm Version)
productpagina
foto:
[IMG]
[/IMG]
Nieuwe(2*) Enermax Apollish Silver 120 mm fans, in originele verpakking
specs: productpagina
foto:
[IMG]
[/IMG]
bieden op cm black, cm neon, cm uv, en Vizo uv green, en op de scythe slip stream (geen originele verpakking, geen bon)
Enermax fans: 20 euro per stuk (originele verpakking, geen bon)
dankLast edited by gillegun; 25-04-2011 at 16:02. Reason: aanvulling
Intel Q6600@3.6Ghz,1.4V cpu Cooled by Prolimatech Megahalems, mobo: MSI P6N Sli Platinum, graka: MSI Ati HD5870 , 2*2GB Patriot Viper DDR2-6400 LL, Samsung Spinpoint F1 750GB 32Mb, Seagate Barracuda 500GB 16MB Cache, Coolermaster M700 psu, Coolermaster Stacker 832 SE(modded to iron man case) and 5 Scythe 120mm Slip Stream 1900Rpm. 8*120MM apolish Silver fans(Enermax) 2*Innovatek Raptorvibes, 2*Scythe Ita Kaze
26-04-2011, 15:33 #2
Wie alles in één keer koopt (62euro inclusief verzendingskosten) (cm black cm blue cm uv, vizo elk twee euro:acht euro, drie scythe aan drie euro stuk: negen euro=17 euro) (twee enermax= 40 euro)=57 euro +verzending: 5.7 euro=korting van 70 cent +gratis innovatek)=good deal!
krijgt van mij gratis een(nieuw ongeopend) Innovatek Case badge set (licht module met vinyl blad, waar je je eigen casebadge mee kan maken en kan belichten) ter waarde van 11,90 euro
case badge
kijk ook es naar andere zoekertjes, bevalt je iets, dan moet je maar eenmalig verzendingskosten betalen
Voor wie zowel de fans, als de innovatek RaptorVibe koopt (plus gratis CaseBadge LED)
krijgt nog wat leuks van mij:
Scythe Casebadge(prijs onbekend) en een Innovatek Casebadge(1.19 euro)+innovatek sticker(0.89 euro) gratisLast edited by gillegun; 27-04-2011 at 07:45.
26-04-2011, 22:33 #3
1/3
upIntel Q6600@3.6Ghz,1.4V cpu Cooled by Prolimatech Megahalems, mobo: MSI P6N Sli Platinum, graka: MSI Ati HD5870 , 2*2GB Patriot Viper DDR2-6400 LL, Samsung Spinpoint F1 750GB 32Mb, Seagate Barracuda 500GB 16MB Cache, Coolermaster M700 psu, Coolermaster Stacker 832 SE(modded to iron man case) and 5 Scythe 120mm Slip Stream 1900Rpm. 8*120MM apolish Silver fans(Enermax) 2*Innovatek Raptorvibes, 2*Scythe Ita Kaze
27-04-2011, 01:18 #4Member
- Erpe-Mere
- 10,644
- 306 (100%)
- 4/16
Beste,
Je zit aan je derde up al, extra info is ook een up.
08-05-2011, 19:58 #5Member
- 21/03/10
- Dé stad
- 4,211
- 36 (100%)
- 0/66
productpagina
foto:
Hoeveel voor deze 3?
08-05-2011, 21:36 #6
voor die scythe's: zo'n drie euro/stuk.
(voor die andere vier: 2 euro per stuk (en uiteraard voor de enermax fans: 20 euro per stuk)
Het liefst verkoop ik alle fans in ene keer, dus ik wacht af of er mss mensen zijn die gans het pakket willen kopen (met combo's en zo). Ik sluit af binnen 48uur.Intel Q6600@3.6Ghz,1.4V cpu Cooled by Prolimatech Megahalems, mobo: MSI P6N Sli Platinum, graka: MSI Ati HD5870 , 2*2GB Patriot Viper DDR2-6400 LL, Samsung Spinpoint F1 750GB 32Mb, Seagate Barracuda 500GB 16MB Cache, Coolermaster M700 psu, Coolermaster Stacker 832 SE(modded to iron man case) and 5 Scythe 120mm Slip Stream 1900Rpm. 8*120MM apolish Silver fans(Enermax) 2*Innovatek Raptorvibes, 2*Scythe Ita Kaze
09-05-2011, 06:21 #7
20€ inclu voor bovenstaand pakket
09-05-2011, 10:32 #8
@goldsaint, bod genoteerd (doe er nog 70 cent bij, en het is perfect?). Ik eindig vanavond met deze topic, laat je dan iets weten
het liefst verkoop ik gans het pakket in 1 keer, dus mocht er tegen vanavond 21u niemand geboden hebben op het totaal pakket, gaan die 7 fans jou richting uitLast edited by gillegun; 09-05-2011 at 11:01.
09-05-2011, 13:37 #9
alé goed dan
20,70€
09-05-2011, 15:39 #10
@goldsaint: genoteerd
kleine korting (dit is laatste dag, dat zoekertje erop staat) normaal gezien 62euro inclusief verzending)= gans het pakket nu afgerond naar 60 euro inclusief verzending (plus gratis innovatek case badge light module)
want het liefst heb ik gans het pakket in één keer kwijt
kijk ook eens naar andere te koop aangeboden spullen, dan is het nog voordeligerLast edited by gillegun; 09-05-2011 at 15:41. Reason: aanvulling
09-05-2011, 20:52 #11
bod ontvangen via mail van 50 euro inclusief. Als die vanavond niet overboden wordt, gaat het naar die persoon.
dus als iemand het pakket wil hebben, nu is je kans. kijk ook naar mijn andere aangeboden spullen, als daar iets is dat je bevalt, kunnen we het nog bespreken rond de prijsLast edited by gillegun; 09-05-2011 at 21:18. Reason: aanvulling
09-05-2011, 21:32 #12
zie hier nergens staan dat deze fans ook nog ergens anders aangeboden worden en denk zelfs dat biedingen via mail ontvangen nie echt toegelaten is, denk ik...
nuja, voor deze prijs haak ik af, mocht die andere zijn bod van 50€ intrekken dan blijft mijn bod geldig. ik zie wel hoe het afloopt.
09-05-2011, 21:37 #13Intel Q6600@3.6Ghz,1.4V cpu Cooled by Prolimatech Megahalems, mobo: MSI P6N Sli Platinum, graka: MSI Ati HD5870 , 2*2GB Patriot Viper DDR2-6400 LL, Samsung Spinpoint F1 750GB 32Mb, Seagate Barracuda 500GB 16MB Cache, Coolermaster M700 psu, Coolermaster Stacker 832 SE(modded to iron man case) and 5 Scythe 120mm Slip Stream 1900Rpm. 8*120MM apolish Silver fans(Enermax) 2*Innovatek Raptorvibes, 2*Scythe Ita Kaze
