    solix's Avatar
    Vlaanderen
    63 (100%)
    DFI LANparty JR P45-T2RS (s775) + Thermalright HR-05 IFX
    Hallo,
    Ik verkoop dit mobo omdat deze niet meer in gebruik is.
    ENKEL is de northbridge cooler er niet op gemonteerd omwille van de schoefkes die kapot zijn (die zal je wel kunnen vinden bij een "doe het zelf" winkel)
    Een Thermalright HR-05 IFX krijg je erbij.
    DFI LANParty:The Best OC Platform! Overclock, Motherboard, Intel, AMD
    Code:
    Product Spec
    LANPARTY JR P45-T2RS
    CPU
    # LGA 775 socket for: - Intel® CoreTM2 Quad and Intel® CoreTM2 Duo
    # Supports Intel Enhanced Memory 64 Technology (EMT64T)
    # Supports Enhanced Intel SpeedStep Technology (EIST)
    # Supports Intel Hyper-Threading Technology
    # Supports 1333/1066/800MHz FSB
    Chipset
    # Intel® chipset - Northbridge: Intel® P45 Express chipset Intel® Fast Memory Access technology - Southbridge: Intel® ICH10R
    System Memory
    # Four 240-pin DDR2 DIMM sockets
    # Supports DDR2 1200(O.C.)/1066/800/667 MHz
    # Delivers up to 12.8Gb/s bandwidth
    # Supports dual channel (128-bit wide) memory interface
    # Supports non-ECC unbuffered DIMMs
    # Supports up to 16GB system memory
    Windows® 32-bit operating system is unable to accurately detect more than 4GB system memory. Therefore, if you are using this operating system, we strongly recommend that you install a less than 3GB system memory.
    Expansion Slots
    # 2 PCI Express (Gen 2) x16 slots dimensionally with x8 transfer rate lanes only (8-lane ports)
    - 2-way CrossFire: One slot operating at x8 (8-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    # 1 PCI Express x1 slot
    # 1 PCI slot
    BIOS
    # Award BIOS
    # 8Mbit SPI flash BIOS
    # CMOS Reloaded
    Audio
    # Realtek ALC885 High Definition audio CODEC
    # 8-channel audio output
    # DAC SNR/ADC SNR of 106dB/101dB
    # Full-rate lossless content protection technology
    # Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
    LAN
    # Marvell 88E8053 PCIE Gigabit LAN controller
    # Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Serial ATA with RAID
    # Intel Matrix Storage technology
    # Supports up to 6 SATA devices
    # SATA speed up to 3Gb/s
    # RAID 0, RAID 1, RAID 0+1 and RAID 5
    IDE
    # JMicron JMB368 PCI Express to PATA host controller
    # Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
    Rear Panel I/O
    # 1 mini-DIN-6 PS/2 mouse port
    # 1 mini-DIN-6 PS/2 keyboard port
    # 1 optical S/PDIF-out port
    # 1 coaxial RCA S/PDIF-out port
    # 6 USB 2.0/1.1 ports
    # 1 RJ45 LAN port
    # Center/subwoofer, rear R/L and side R/L jacks
    # Line-in, line-out (front R/L) and mic-in jacks
    Internal I/O
    # 3 connectors for 6 additional external USB 2.0 ports
    # 1 connector for an external COM port
    # 1 front audio connector
    # 1 CD-in connector
    # 1 IrDA connector
    # 6 Serial ATA connectors
    # 1 40-pin IDE connector
    # 1 floppy connector
    # 1 24-pin ATX power connector
    # 1 8-pin 12V power connector
    # 1 front panel connector
    # 3 fan connectors
    # 1 download flash BIOS connector
    # EZ touch switches (power switch and reset switch)
    Power Management
    # ACPI and OS Directed Power Management
    # ACPI STR (Suspend to RAM) function
    # Wake-On-PS/2 Keyboard/Mouse
    # Wake-On-USB Keyboard/Mouse
    # Wake-On-LAN
    # Wake-On-Ring
    # RTC timer to power-on the system
    # AC power failure recovery
    Hardware Monitor
    # Monitors CPU/system/Northbridge temperature and overheat alarm
    # Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    # Monitors the speed of the cooling fans
    # CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
    # 4 layers, microATX form factor
    # 24.5cm (9.64") x 24.5cm (9.64")
    prijs: min. 45€ excl.
    successor's Avatar
    Ham 3945
    546 (100%)
    €45 excl.
    Carmen is het allerliefste meisje van de hele wereld
    solix's Avatar
    Vlaanderen
    63 (100%)
    Quote Originally Posted by successor View Post
    €45 excl.
    genoteerd,
    Morgen 28/02/09 om 12.00 sluit ik af.
    successor's Avatar
    Ham 3945
    546 (100%)
    De originele northbridge koeler zit er toch ook bij neem ik aan ?
    successor's Avatar
    Ham 3945
    546 (100%)
    De boden die zijn ingetrokken heb ik weer verwijderd, op vraag van de TS.
    Mocht iemand er nog om malen, de ingetrokken boden zijn :
    Diegson met €50 excl
    Domingo6611 met €55 excl.
    Mijn bod van €45 excl blijft nog wel staan.
    solix's Avatar
    Vlaanderen
    63 (100%)
    Oke,
    morgen sluit ik af om 19.00
