    Morkhoven
    Homeserver / NAS (Raidcontroller)
    Wegens aanschaf van een NAS systeem / Synology NAS doe ik mijn voorgaande NAS / Homeserver systeem weg. Hieronder de gegevens:
    • Thermaltake Kandalf Case
    • Intel Core i5 2400 Sandy Bridge
    • Gigabyte GA-Z68X-UD3H-B3 moederbord
    • Corsair Vengeance 16GB (4x4GB) 1600MHz DDR3 (CMZ16GX3M4A1600C9 9-9-9-24)
    • OZC Agility3 60GB SSD
    • Corsair RM650 650W PSU
    • 4 x Samsung HD103SJ 1Tb (bedrijfsuren zie foto's op 2ehands)
    • 3 x Samsung HD103UJ 1Tb (bedrijfsuren zie foto's op 2ehands)
    • 1 x WD10EACS-00ZJB0 1Tb (bedrijfsuren zie foto's op 2ehands)
    • Promise Supertrak EX8654 RAID Controller 4-Port Internal & 4-Port External PCI-E SATA II / SAS RAID controller, met CD, handleiding en low profile bracket, inclusief SFF-8087 naar 4x SATA+POWER kabel. VMWARE ESX 4.x compatibel. RAID 0, 1, 1E, 6, 5, 10, 50, 60
    Wat meer uitleg rond de RAID Controller:
    Enterprise-Class RAID Reliability
    SuperTrak EX SAS and SATA RAID controllers are stable, robust platforms that can be trusted. Built on a leading edge hardware design, supported by a RAID stack developed and refined over more than 15 years, they incorporate a single chip solution for optimized reliability with 512MB data cache onboard, an available 72 hour battery backup module, and a x8 PCI-Express interface to the host.
    The SuperTrak EX line of SAS and SATA RAID controllers, with RAID 5 and RAID 6 support, protects your mission critical data by delivering the data protection features you expect from leadership solutions. Features such as global and dedicated hot spares, RAID level migration, media patrol, read check table, and bad sector remapping offer the most reliable data protection solutions in their class.
    Easy Management
    The new web-based Promise Array Manager Professional (WebPAM™ PRO) makes SuperTrak RAID Controllers easy to manage for both Windows and Linux environments through the browser-based graphical user interface to create, delete, expand, and convert disk arrays from anywhere in the world.
    In the event of a drive or data channel failure, WebPAM PRO supports an array of notification options including text and email, as well as an audio alarm located directly on the STEX RAID controller
    Specifications:
    Controller Configuration
    • Four internal SAS/SATA ports at 3Gb/s
    • Four external SAS/SATA ports at 3Gb/s
    — One SAS SFF-8088 connector
    — One SAS SFF-8087 connector
    • 1.2Ghz Intel 81348 XScale I/O processor
    • Onboard 512MB ECC DDR II memory
    Hardware Features
    • PCI-Express x8 host bus interface
    • Hardware XOR engine to offload parity calculation
    • Hardware RAID 6 accelerator
    • Low-profile MD2 form factor
    • Optional on-board battery backup unit for data retention up to 72 hours
    Supported RAID Levels
    RAID 0 – Data striped across 1-16 drives for increased performance, but no data protection
    • RAID 1 – Mirrored pair of drives for data protection with increased read performance • RAID 1E – Data mirroring extended to maximize balanced performance. Allows odd number drive mirroring
    • RAID 5 – Striped parity on 3-16 drives, ultimate data protection, capacity and performance balance
    • RAID 6 – Double parity for maximum data protection on 4-16 drives; allows double drive failures without downtime or data loss
    • RAID 10 – Mirrored pair of RAID 0 for double drive failure protection; can be split into two RAID 0 sets
    • RAID 50 – Striped multiple RAID 5 sets to improve performance and provide additional data protection
    • RAID 60 – Striped multiple RAID 6 sets to allow multiple drive failures to achieve high-data availability
    RAID Fault Tolerance and Robustness Features
    • Multiple logical drive support enables combining different RAID levels on one set of disks
    • Read Check table to avoid data read errors
    • PerfectRAID™ technology for error handling and recovery of fatal, media and disk errors
    • Support hot swap of failed drives and hot spares
    • Automatic/Manual rebuild of hot spare drive
    • Background initialization for instant drive availability
    • Supports bad sector remapping
    • Variable stripe block size support to meet various application requirements
    • Synchronization can be scheduled periodically for RAID data consistency
    Web-based Promise Array Manager
    • Creates, deletes, expands, and converts disk arrays remotely
    • Media Patrol and Redundancy Check scheduling
    • Monitors drive, array, and enclosure status and provides online event logging
    • Email notification of drive, array, controller or enclosure events (e.g. error or degrade conditions)
    • Remote management based on industry standard CIM/WBEM
    • Interface displays in 10 languages
    • CLI support
    • Remote firmware update
    Operating System Support
    • Microsoft Windows Vista, 2000, XP, Windows Server 2003, Windows Server 2008
    • Red Hat Linux, SuSE Linux, Miracle Linux, Fedora Core, Linux open source driver (32/64-bit)
    • FreeBSD,FreeNAS, VMware ESX 3.x, 4.x
    Bieden kan vanaf 100€. Bieden sluit af op 07/08 om 20u
    Wordt niet verzonden en kan alleen opgehaald worden (regio Herentals).
    Staat tevens op 2ehands met foto's erbij (https://www.2dehands.be/plaats/m1441...reviousPage=lr)
    Slikkah's Avatar
    Meeneem ( Antw )
    356 (100%)
    €100 opgehaald
    Morkhoven
    Heb een bod gehad van 105 (opgehaald) op 2ehands. Ik sluit woensdagavond om 20u overigens af, heb de post net ook aangepast.
    mechelen
    Enig idee van idle vermogen?
    Morkhoven
    Geen flauw idee op dit moment. Kan het wel uitmeten, maar is niet voor vandaag want heb alle disken gedemonteerd om de case en fans te reinigen. Zal het je morgen weten te zeggen als ik alles terug gemonteerd en draaiende heb
    mechelen
    110 afgehaald
    Morkhoven
    Bod genoteerd
    Morkhoven
    Quote Originally Posted by on4ill View Post
    Net uitgemeten en zit op 97 Watt idle (zonder monitor of datatransfers)
    mechelen
    Thx. Very nice met al die drives erbij. Is men Pentium D extreme setup die al jaren draait jaloers op
    Bod blijft uiteraard geldig.
    Morkhoven
    Post afgesloten, hoogste bod voor On4ill en dus ook verkocht.
