    Kluisbergen
    TK: Monitor Audio Vector 20 centerspeaker
    Goede centerspeaker, uitstekende prijs/kwaliteit. Kan ook zijwaarts geplaatst worden.
    Is denk ik een jaar of twee oud. Te koop wegens vervangen door een kleiner exemplaar.
    Vector 20 centerspeaker.
    Goede staat, niks op aan te merken. Hing oorspronkelijk boven mijn TV maar is toch wat groot. Ik kan eventueel een wandbeugeltje meeleveren.
    Info van MA site:
    The compact V20 is a versatile speaker that can be used either horizontally for centre-channel home cinema duties or vertically as a left/right satellite in multi-channel or stereo applications around the home.
    The V20 shares the tonal characteristics of the V10, via a 1" gold C-CAM® dome tweeter and a 4" MMP®II bass driver but has the extended bass response necessary for the accurate reproduction of movie dialogue. The cabinets are constructed of a high density moulded polymer, ideal for creating a strong and rigid enclosure and finished with a 'soft touch' rubberised black skin, which lends a wonderfully novel and tactile quality to the product. The front baffles are of MDF, which are held in place with a single through-bolt driver fixing/ bracing method and are coated in either a deep high-gloss piano black black or white lacquer (with white cabinet) or a more traditional walnut wood grain vinyl. Front porting, recessed terminal panel and keyhole fixing points allow for easy wall installation.
    - See more at: V20 | Vector | Monitor Audio
    4" Driver with MMPII cone technology. 25mm gold C-CAM tweeter. Magnetically shielded drivers. For safe use near sensitive microprocessor equipment or LCD/Plasma displays. Rigid moulded polymer cabinet with MDF baffle. Rear ported. Metal mesh grilles. Front porting for wall or cabinet mounting. Single point wall bracket insert. Single through-bolt driver fixing/ bracing method . Finished in high gloss piano black, piano white or wood grain baffle with a soft touch rubberised cabinet. (The piano white baffle has a white rubberised cabinet to suit.) - See more at: V20 | Vector | Monitor Audio
    Bieden mag vanaf 40 euro, excl verzending.
    Kluisbergen
    Upje.
    Kluisbergen
    Up2.
    Kluisbergen
    Up3: ligt nog altijd werkloos bij mij. Een 6-pack Duvel is ook goed
    GiJay's Avatar
    89 (100%)
    Voor een 6-pack duvel heb je een deal!
    *Bij deze deel ik officieel een bod uit van een 6-pack duvel.
    The retardedness is strong on this forum!
    Kluisbergen
    genoteerd, ik stuur een pm
    Kluisbergen
    Afgehaald, deze mag toe.
