Thread: Onkyo TX-SR605
    Struber's Avatar
    Blaasveld City
    48 (100%)
    Onkyo TX-SR605
    Ik verkoop men huidige versterker aangezien ik door plaatsgebrek geen surround meer kan opstellen en dus daardoor een nieuwe Stereo versterker ga kopen.
    De Versterker is als nieuw, werkt perfect en komt met de nodige toebehoren (AM-antenne, afstandsbediening)
    De Specificaties:
    Power Output
    Front L/R
    90 W + 90 W (8 ohms, 20 Hz–20 kHz,
    0.08%, 2 channels driven, FTC)
    105 W + 105 W (8 ohms, 1 kHz, 0.7%,
    110 W + 110 W (6 ohms, 1 kHz, 0.1%,
    Center
    90 W (8 ohms, 20 Hz–20 kHz, 0.08%,
    105 W (8 ohms, 1 kHz, 0.7%, 2 channels
    driven, FTC)
    110 W (6 ohms, 1 kHz, 0.1%, 2 channels
    driven, FTC)
    Surround L/R
    Surround Back L/R
    Dynamic Power
    210 W (3 ohms, 1 ch)
    180 W (4 ohms, 1 ch)
    110 W (8 ohms, 1 ch)
    THD (Total Harmonic Distortion)
    0.08% (Rated power)
    Damping Factor
    60 (Front, 1 kHz, 8 ohms)
    Input Sensitivity and Impedance
    200 mV/47 k-ohms (Line)
    Output Level and Impedance
    200 mV/470 ohms (Rec out)
    Phono Overload
    Frequency Response
    5 Hz–100 kHz/+1 dB, -3 dB (Direct mode)
    Tone Control
    ±10 dB, 50 Hz (Bass)
    ±10 dB, 20 kHz (Treble)
    Signal-to-Noise Ratio
    100 dB (Line, IHF-A)
    Speaker Impedance
    6 ohms–16 ohms
    Video Section
    Input Sensitivity/Output Level and Impedance
    Video
    1 Vp-p/75 ohms (Component and S-Video Y)
    0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
    0.28 Vp-p/75 ohms (S-Video C)
    1 Vp-p/75 ohms (Composite)
    Component Video Frequency Response
    5 Hz–50 MHz
    Tuner Section
    Tuning Frequency Range
    FM
    87.5 MHz–107.9 MHz
    AM
    530 kHz–1,710 kHz
    FM/AM Preset Memory
    40 stations
    Power Supply
    AC 120 V, 60 Hz
    Power Consumption
    6.5 A
    Dimensions (W x H x D)
    17 1/8" x 6 7/8" x 14 13/16"
    (435 x 174 x 377 mm)
    Weight
    25.1 lbs. (11.4 kg)
    Kleur: Zilver
    Indien er vragen zijn, aarzel niet ze te stellen.
    minimumprijs: €250
    Meeneemprijs: €300
    Er wordt niet verzonden, de versterker kan getest en afgehaald worden in Blaasveld.
    specs: VIA EPIA MII 12000 -//- Hush Mini-ITX Extended -//- Geil 256mb pc3200 Value -//- SlimLine DVD 16/48x -//- Seagate Barracuda IV HD 40GB @ 7200rpm
    Struber's Avatar
    Blaasveld City
    48 (100%)
    Up 1/3
    Struber's Avatar
    Blaasveld City
    48 (100%)
    Up: 2/3
