Thread: New Graphics card (new system?)
15-12-2008, 14:44 #1Member
- 21/02/03
- Kessel-Lo
- 3,918
* UPDATE *
't Ziet er naar uit dat ik ook een nieuwe harddisk ga mogen aanschaffen
Enige suggesties hier of maakt het niet echt uit? How big is too big? Want ik zie zo HDD's an 1.5 TB
'k Had dit origineel elders - op een engelstalig forum - gepost maar er kwam maar geen reaktie op dus repost ik het hier... in't engels dus, dat zal voor de meesten wel geen probleem vormen zeker?
It's been a few years since I frequented this site and World of Warcraft stole me away from the hardware scene. Where there once was a time when I would have known what to buy and what not to buy I now find myself in need of some advice on this matter. And where better to ask it then here amirite?
I am looking for a new graphics card and perhaps a whole new core system altogether. When making suggestions please keep a few things in mind:
- good overclocking potential while remaining stable for every day use. I don't need some motherboard that only runs good when it feels like it or a cpu that has a 1 in 6 chance of being a good oc'er.
- readily available. Not some exotic graphics card that I need to import from Malaysia and have to wait half a year for.
- reasonably priced. I know that's all relative but usually the latest and gratest also costs an arm and a leg while the next best thing is already a lot more, you guessed it, reasonably priced
Also another downside of being out of the scene for so long is that I don't know what is considered reasonably priced anymore. 200-300 € for a good cpu or motherboard and 500€ for a top end vidcard is what I'd expect to see 4 years ago but now? I haven't got a clue...
Now first things first. The graphics card. I'm getting artifacts in games and thought the graphics card isn't necessarily the culprit it usually is. I don't have any spare hardware I can switch out to be sure but it's not the system memory, I know that much.
Performance wise I'm thinking along the lines of a next best thing type of card. Basically so I end up with something that is still very good now and for some time to come but not the priciest of the lot.
Unless offcourse there is a new line of cards coming up in a couple of months (preferably no more then 1-2 months, 4 months at the most) in wich case a low budget gaming card will do.
On a side note I'm currently using an old 20 pin Antec PSU since I blew my (also old
) OCZ 24 pin up a few years ago and haven't bothered to try and fix it. I'm guessing this may also need upgrading?
Then on to the core components: Motherboard, CPU and Memory. Perhaps even a couple hard disks.
This isn't a must like the graphics card is but I do feel it's time I upgraded this old beasty. For those who wonder that's an AMD3000+ on an MSI K8N SLI Platinum with 2* 512MB TCCD and a 7900 GTX so yeah, óóóóóóóóóld! :P
With these components holding off a bit is no problem if something bigger and better is coming out soon. I've had a breef look around and a thread about the Phenom 2 X4 caught my eye? Though I hold my hart when I'm thinking of what it might cost ^^ Eh, I think I'm daydreaming again
*edit* Perhaps not, Techzine reports ~270€ for a Black Edition :o
PS: It's by no means a must but it would be nice if all the components were available from the same shop. It Would save some cash on shipping/driving around.Last edited by Sacristar; 19-12-2008 at 17:51.
15-12-2008, 16:57 #2Member
- 23/04/06
- Tessenderlo
- 8,795
- 11 (100%)
- 26/29
OK, int lang en breed uitgelegd
ma soit, mijn engels is redelijk goed dus ik heb alles wel kunnen vertalen.
Op gebied van prijs is alles wel veel goedkoper geworden, voor +-1000€ heb je al een zeer deftige pc (kast alleen). Best even je budget vermelden zodat we een voorstel kunnen doen.
Over die Phenom II : die wordt pas op 8 januari gelanceerd op de CES beurs, eerder zal je die niet in winkels zien liggen denk ik. Het zou wel een goeie overclocker zijn dus als je persee een AMD cpu wil is het misschien de moeite om op te wachten.
Op gebied van grafische kaarten is de HD4xxx serie van ATI momenteel wel het meest populair, de HD4850 heeft met een prijs van +-150€ dan ook de beste prijs/prestatieverhouding, de HD4870 is nog een stuk sneller maar die kost al >200€. De snelste is de HD4870X2 en heeft atm ook de prestatiekroon in handen, maar dan zit je al aan +-450€, zoals je zelf al zei :
Vroeger zouden deze kaarten dubbel zoveel gekost hebben, maar ATI heeft met hun nieuwe strategie het GPU landschap op zijn kop gezet. Denk dus zeker niet dat een kaart van 150€ traag isreasonably priced. I know that's all relative but usually the latest and gratest also costs an arm and a leg while the next best thing is already a lot more, you guessed it, reasonably priced
15-12-2008, 17:39 #3Member
- 23/05/05
- Bredene
- 8,877
- 14 (100%)
- 0/7
Lekker engels
. Maar brief ipv breef, of course ipv offcourse, heart ipv hart, than ipv then. Sorry, force of habit ^^
Zoals mette aangeeft zou ik Intel gaan. Voor 1000€ heb je al 'n high-end systeem dezer dagen.
ff iets samengesteld, heb er geen case ingestoken omdat je die niet vermeld had.
1 x PC Power & Cooling Silencer 610 EPS12V voeding
1 x Gigabyte GA-EX58-DS4 socket 1366
1 x Intel Core i7 Quad Core 920 PC1333 8MB 2,67GHz socket 1366
1 x Sapphire HD4870 1Gb DDR5 PCI-express
1 x Mushkin 2 x 2Gb DDR3 PC10666 CL9 Silver (996637)
€1.066,90 bij jaha.be.
Voor 1000€ lijkt me deze setup 't best. Je kan besparen door een socket 775 Intel systeem te nemen dat niet zodanig veel trager is, maar dan kan je later niet meer upgraden zonder cpu/mobo/ram samen te kopen.no votes
15-12-2008, 17:59 #4Approved 9-lifer
- 02/01/03
- Oarelbeke
- 7,272
Ziet er inderdaad zeer mooie setup uit voor die prijs
@engels gedoe :
De fouten die hij had zijn er wel die ongelooflijk veel Engelstaligen maken, ik heb er ook al veel gezien die niet eens het verschil kennen tussen then & than =o (wel allemaal Amerikanen eigenlijk)DE plaats om games te kopen/verkopen : www.gameswap.be
My System : GA-X58-UD5 / i7 920 D0 (stable @ 4GHz) @ Scythe Mugen 2 / MSI GTX660 OC / 6GB DDR3 @ 1528 MHz
Wife's System : GA-X58-UD3R / i7 920 D0 (stable @ 4.2GHz) @ Noctua NH-D14 / Club3D HD5850 / 6GB DDR3 @ 1600MHz
Atheïsm : the solution || The internet's biggest flaw. (click me!)no votes
15-12-2008, 18:23 #5Member
- 21/02/03
- Kessel-Lo
- 3,918
Tja, 'k ben geen native speaker hé ;-) en proof readen doe ik alleen maar als't op punten staat
maar alvast bedankt, 'k denk dat ik toch sowieso op zo'n Phenom II ga wachten maar ik zal al eens naar die kaartjes en zo'n psu kijken.no votes
15-12-2008, 20:17 #6Member
- 03/09/02
- Leuven
- 850
15-12-2008, 20:54 #7Member
- 04/11/03
- Brugge
- 13,390
- 16 (100%)
- 7/18
Fractal Design Node 304 || Asus H87I-PLUS || Intel i5 4570 || 16GB DDR3 || EVGA 1080 Ti SC Black Edition ||Samsung 840 EVO 250GB || Dell U3818DW
Fractal Design Define XL || Gigabyte 790X-UD3P || AMD Phenom II X4 955 || 4GB DDR2 || HD4850 || 20TB
16-12-2008, 01:12 #8Member
- 21/02/03
- Kessel-Lo
- 3,918
'k was er nog net bij toen Core2Duo de markt veroverde ;-) Maar die nieuwe amd gaat wel tof worden, zeker aan die prijs
BTW, hoe zit dat met Sapphire dezer dagen?
Een breed gamma en vlotjes verkrijgbaar, dat wel. Maar veel marge om te overclocken was er meestal niet.Last edited by Davion; 16-12-2008 at 13:28.
16-12-2008, 11:40 #9Member
- 01/06/04
- Waregem
- 6,159
- 35 (100%)
- 0/4
De Phenom II zal sowieso de concurrentie kunnen aangaan met de C2Q, maar in vergelijking met de i7 zal die CPC de performance niet halen. Overclockability zit het wel snor ... als je van plan bent subzero te gaan: op lucht haal je geen 4GHz stabiel, wellicht rond de 3,6-3,8GHz.
19-12-2008, 17:52 #10Member
- 21/02/03
- Kessel-Lo
- 3,918
Bump, originele post aangepast ivm nieuwe harddisk.
19-12-2008, 18:13 #11Member
- 06/11/03
- Riemst
- 2,306
- 13 (100%)
- 2/3
Ik zou persoonlijk niet zoveel geld uitgeven aan één harde schijf, en die dan ook nog eens enkel gebruiken als schijf voor zowel OS + Data...
Dus ik raad u aan om een iets kleinere te kopen voor u OS ( 320Gig ) en nog een andere voor de data ( mp3,film,spel,... )no votes
19-12-2008, 22:46 #12Member
- 21/02/03
- Kessel-Lo
- 3,918
Da's ook de bedoeling. Mijn oudste schijf is het echt aan't begeven en al mijn muziek ed staat daar op. die wil ik liever niet kwijt =)
