    Matti's Avatar
    Question Harman/Kardon AVR247 | receiver
    versterker: http://www.mediakomeet.nl//?item=1000404&from=vergelijk
    boxen: http://www.qplaza.nl/product_info.php?products_id=606
    Audio
    Stereo Mode
    Continuous Average Power (FTC) per Channel : 65 Watts per channel, 20Hz – 20kHz, @ <0.07% THD, both channels driven into 8 ohms
    Seven-Channel Surround Modes, Power per Individual Channel,
    All Channels Operating at Full Power :
    Front L & R Channels : 50 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Center Channel : 50 Watts @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Surround Channels (L & R Side, L & R Back) : 50 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
    Input Sensitivity/Impedance, Linear (High-Level) : 200mV/47k ohms
    Signal-to-Noise Ratio (IHF-A) : 100dB
    Surround System Adjacent Channel Separation :
    Dolby® Pro Logic® I and II : 40dB
    Dolby® Digital : 55dB
    DTS® : 55dB
    Frequency Response at 1W (+0dB, –3dB) : 10Hz – 130kHz
    High Instantaneous Current Capability (HCC) : ±35 Amps
    Transient Intermodulation Distortion (TIM) : Unmeasurable
    Slew Rate : 40V/µsec
    FM Tuner
    Frequency Range : 87.5 – 108.0MHz
    Usable Sensitivity : IHF 1.3µV/13.2dBf
    Signal-to-Noise Ratio : Mono/Stereo 70/68dB
    Distortion : Mono/Stereo 0.2/0.3%
    Stereo Separation : 40dB @ 1kHz
    Selectivity : ±400kHz, 70dB
    Image Rejection : 80dB
    IF Rejection : 90dB
    AM Tuner
    Frequency Range : 520 – 1720kHz
    Signal-to-Noise Ratio : 45dB
    Usable Sensitivity : Loop 500µV
    Distortion : 1kHz, 50% Mod 0.8%
    Selectivity : ±10kHz, 30dB
    Video
    Television Format : PAL/NTSC
    Input Level/Impedance : 1V p-p/75 ohms
    Output Level/Impedance : 1V p-p/75 ohms
    Video Frequency Response :
    Composite and S-Video : 10Hz – 8MHz (–3dB)
    Component Video : 10Hz – 100MHz (–3dB)
    HDMI™ : HDMI™ switching with 1080p pass-through
    Wat vinden jullie hiervan?
    Pluspunten?
    Minpunten? Beperkingen?
    solix's Avatar
    Vlaanderen
    63 (100%)
    Ik zelf ben content van mijne avr247.
    Alleen vind ik het jammer dat de receiver de native resolution van 1366 x 768p niet ondersteunt.
    Het ondersteunt alleen 720p of 1080p.
    maar swat als ge meer info wilt hebben check dan deze link
    Matti's Avatar
    Thnx!!
    ik ben een absolute leek... wat wil dit zeggen in messentaal
    Mr. Humphries's Avatar
    Kapellen/Turnhout
    16 (94%)
    Dit wil alleen wat zeggen voor als je beeld via je receiver doorstuurt, en dan nog, volgens mij heeft geen enkele versterker dit. Voor de rest ziet dit er goed uit voor zijn prijs. Enkel vind ik precies het vermogen wat te weinig, niet om luider te kunnen spelen, maar eerder voor betere kwaliteit bij lagere volumes etc.
    www.servicepointturnhout.be voor reclame en beletteringen
    Dakantochnie's Avatar
    Het Stad
    Lage vermogens is typisch H/K. Zolang je geen H/K amp met bv JBL speakers gaat combineren (die hopen vermogen vragen), is er geen probleem.
    Bovendien is H/K wel een merk dat qua vermogens vrij goed zijn beloftes nakomt. Je hoeft trouwens geen hoog vermogen te hebben om goede klank te krijgen of luid te gaan.
    Nu, ik vraag mij langs de andere kant wel echt af hoe je erbij komt om een mid-end versterker (want daar gaat het om) te combineren met low-end boxen. Dat heeft langs geen kanten zin, aangezien de versterker details gaat doorgeven die de boxen compleet gaan wegfilteren.
    Als ik jou was zou ik een Marantz amp nemen (even goed, maar wel goedkoper) en boxen van een ander merk. Zo ga je uiteindelijk beter klinkend materiaal verkrijgen.
    Zeg misschien eens je totaalbudget, waar het voor moet dienen (muziek? welke soort, enz), hoe groot de ruimte is, en alle andere details. Dan kan ik hier zelfs iets voorstellen.
    En op de achtste dag schiep Hij dakantochnie. - Epyon | Lang leve Dakantochnie. - Cyberkef
    Ik lust je wel dakantochnie! - Matti | Dakantochnie. Ofte het zijn, het bestaan en het wezen. - Manu
    Der komt NIETS zinnig uit uwen bek. En u karakter is zo rot als u toekomstig onderstel. - GADGET
    Vroeger is over en later zover. De kunst is het hier zijn, Dakantochnie - een ster. - Robust2
    Matti's Avatar
    olas...dakantochwel is een expert
    Ik heb het zien staan op een site en zoek al lang een surround...
    ruimte is zo'n 30m² (living) en dient vooral voor muziek, gamen met ps3 en films
    Budget tussen de 500-1000 euro
    Thnx alvast!!!
    Het Stad
    http://www.bestekeus.nl/product_info...-pId-6703.html
    http://www.bestekeus.nl/product_info...pId-12854.html
    Dat is een combinatie (of toch ongeveer) die hier al heel dikwijls de revue is gepasseerd, maar ik blijf erbij dat je niet gemakkelijk meer waar voor je geld gaat krijgen.
    Marantz + JBL gaat een nogal zware klank opleveren (de subwoofer gaat zich amuseren, je buren iets minder), maar nog niet van het Logitech-allooi (en de sub kan je trouwens uitschakelen).
    De amp is een pak duurder dan de boxen, maar dat heeft twee redenen:
    1) De boxen zijn gewoon onderprijsd.
    2) Ik heb expres gekozen voor een amp die eigenlijk te goed is.
    De reden die achter nummer 2 schuilt, is dat je zo gerust eens een feestje kan geven zonder je schrik hoeft te hebben dat je alles opblaast (want immers: een te zwakke versterker aan krachtige boxen is een groter probleem dan een te krachtige versterker aan zwakkere boxen) + vanaf het model 5002 heb je bij Marantz HDMI-connectoren, en het model daaronder nog niet.
    Wat je ook kan doen is hoogwaardiger boxen kopen, en beginnen met een 2.0 opstelling en dan later speakers bijkopen. Dat gaat je uiteraard veel meer geld kosten, maar dat zal je ook wel voelen aan alles. Duurdere speakers gaan langer mee, klinken uiteraard beter maar behouden ook beter hun restwaarde. Aan u de keuze.
    Havoc's Avatar
    37 (100%)
    Over de versterker kan ik niet veel zeggen, maar de boxen die dakantochnie aanraadt, heb ik zelf twee jaar geleden gekocht. Zijn een echte aanrader: uitstekend geluid voor een heel aanvaardbare prijs! Hier gecombineerd met een low-budget Sony-amp helaas, daar moet ik binnenkort eens verandering in brengen...
    Ceci n'est pas une signature
    Kapellen/Turnhout
    16 (94%)
    Ik zou ineens voor goede boxen gaan, goede boxen gaan een lifetime mee en zijn helemaal niet snel verouderd. Voor een versterker zou ik zien of hij een optische ingang heeft, zodat je dit digitaal (beste kwaliteit) kan aansluiten.
    Het Stad
    Quote Originally Posted by Havoc View Post
    Sony levert over het algemeen wel degelijk materiaal af, maar ik heb (en dat heb ik u ook al gezegd) soms echt serieus mijn twijfels over hoe die met wattages omgaan. Als je moet afgaan op de cijfers op hun toestellen heeft een high-end amp bij hen evenveel RMS-vermogen als een low-end model.
    Ik veronderstel dus dat je wat je gezond verstand moet gebruiken en ongeveer een kwart van het vermogen als echt bruikbaar moet aanzien.
    Quote Originally Posted by Mr. Humphries View Post
    Goede boxen verouderen niet traag, die verouderen gewoon niet technisch gezien. Het enige dat kan gebeuren is dat een onderdeel het begeeft (wat heel zelden gebeurt als je alles normaal behandelt), of dat er een box scheurt (wat wel is kan voorkomen na een jaar of 20).
    Maar qua klank zie ik niet zo ontzettend veel verschil tussen boxen van nu en 20 jaar terug.
