Thread: TFT monitor
04-05-2005, 19:01 #1Member
- 12/11/03
- Meulebeke
- 2,730
TFT monitor
llow,
Zoals de titel dus zegt, ben ik op zoek naar een deftige TFT monitor.
Het is niet de bedoeling om er veel mee te gamen, maar vooral om films te bekijken, internet, ...
Ik wil dus geen TN paneel, maar liever een overdrive MVA/PVA paneel, liefst nog verstelbaar in hoogte enzo ook.
mijn budget is 500 à 600 euro. Wat raden jullie aan?no votes
04-05-2005, 19:16 #2Approved 9liver
- 18/04/03
- Hasselt
- 14,855
- 23 (100%)
- 4/79
ik gebruik hier de samsung syncmaster 913n
is 19inch screen
heel goed scherm
wat info:
SAMSUNG 19" TFT monitor ( SM913N ) € 437,96 inlcu btw
158375
Artikelnr. fabrikant: MJ19ESKSB
It's time to create a new space in your life, with Samsung's TFT products. Offering you tomorrows technology today, these super slim monitors take up a third of the space a traditional display would take. With inspiring, futuristic styles, and a host of user-friendly features they conspire to make the way you work a more enjoyable experience.
Bekijk specificaties: Standaard Uitgebreid
Specificaties
General
Display Type Flat panel display / TFT active matrix
Width 41.7 cm
Depth 21.6 cm
Height 42.5 cm
Weight 6 kg
Enclosure Colour Silver
Compatibility PC
Expansion / Connectivity
Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
Manufacturer Warranty
Service & Support 3 years warranty
Service & Support Details Limited warranty - 3 years
Miscellaneous
Features Wall mountable
Compliant Standards TCO '03, TUV GS, DDC-2B, EPA Energy Star, ISO 13406-2, NUTEK
Flat Panel Mount Interface 100 x 100 mm
Cables Included 1 x VGA cable
Power
Form Factor Internal
Voltage Required AC 110/230 V ( 50/60 Hz )
Power Consumption Operational 38 Watt
Power Consumption Stand by / Sleep 1 Watt
Software / System Requirements
Software Included Drivers & Utilities, Magic Tune
Environmental Parameters
Min Operating Temperature 10 C
Max Operating Temperature 40 C
Humidity Range Operating 10 - 80%
Display
Diagonal Size 19"
Dot Pitch / Pixel Pitch 0.294 mm
Max Resolution 1280 x 1024 / 75 Hz
Colour support Up to 16.2 million colors
Max Sync Rate (V x H) 75 Hz x 81 kHz
Video Bandwidth 140 MHz
Response Time 8 ms
Controls / Adjustments Brightness, contrast, H/V position, sharpness, colour balance, colour temperature
OSD Languages English, German, French, Italian, Swedish, Russian, Spanish
Interface VGA (HD-15)
Features MagicBright, MagicTune
Image Colour Temperature Adjustable
Image Brightness 300 cd/m2
Image Max H-View Angle 160
Image Max V-View Angle 160
Video Input
Analogue video Signal RGB
___________________________-
deze info komt van eurosys
is een prima scherm in heb dien in duitsland aan 390euro gekocht bij snogard
04-05-2005, 19:31 #3Member
- 12/11/03
- Meulebeke
- 2,730
ahja nog een belangrijk detail: ik heb GEEN DVI-aansluiting
en vanzelfsprekend moet het een 19 inch zijnLast edited by simpele duif; 04-05-2005 at 20:06.
04-05-2005, 20:14 #4Approved 9liver
- 18/04/03
- Hasselt
- 14,855
- 23 (100%)
- 4/79
die samsung wat ik voorstel is een D-sub en is 19inch
04-05-2005, 20:20 #5Member
- 17/01/03
- Semmerzake
- 5,166
- 3 Post(s)
- 17/31
Samsung 193P voor EUR 628,00 (iets duurder dan je voor ogen had, maar is wel de moeite):
- Diagonaal: 19"
- Kijkhoek: 178° / 178°
- Responstijd: 20ms
- Helderheid: 250cd/m²
- Contrast: 1000:1
- Verstelbaar in hoogte, kantelbaar
Dit scherm is niet het beste voor games, maar voor 2D-werk is het een pak beter dan bv. de Samsung 913N (wat wel een mooi scherm is hoor, maar het is gericht op gamen en dat gat wat ten koste van de 2D-kwaliteit).PC: R5-2600X | X370-Pro | 2x8GB | Samsung 960 Pro 512GB | WD 4TB | GTX 660 | Eizo CX240 | Steinberg UR22MkII | 2x JBL LSR305
MCE: C2D E8400 | GA-X38-DQ6 | 4GB | GT240 | Samsung 850 EVO 256GB | Origen S16V | Panasonic P46VT20 | Marantz SR7500 | JBL SCS178
NAS: G1840T | H87I+ | 8GB | Samsung 850 PRO 256GB | 5x WD Red 4TB | OpenMediaVault
PHOTO: 1D MkIIN | EF 24-70 f/2,8 L USM | EF 70-200 f/4 L USM | EF 100-400 f/4,5-5,6 L USM IS | 430EX | Selphy CP800no votes
04-05-2005, 20:56 #6Member
- 12/11/03
- Meulebeke
- 2,730
en deze: http://www.tones.be/shop_product.php?idx=100823
die ziet me er wel het interessants uit qua specs, maar het lijkt er op dat je dat scherm niet kan verstellen?
edit: laat maar zitten, heeft geen vga-aansluiting...Last edited by simpele duif; 04-05-2005 at 20:57.
04-05-2005, 21:00 #7Member
- 17/01/03
- Semmerzake
- 5,166
- 3 Post(s)
- 17/31
04-05-2005, 21:15 #8Member
- 12/11/03
- Meulebeke
- 2,730
aha
dan zal het dat scherm worden, als het verstelbaar isno votes
04-05-2005, 21:26 #9Member
- 17/01/03
- Semmerzake
- 5,166
- 3 Post(s)
- 17/31
De specs zien er zeker niet slecht uit. Laat AUB iets weten eens je die hebt...
04-05-2005, 21:28 #10Member
- 12/11/03
- Meulebeke
- 2,730
hmm, dat scherm kan 20 graden kantelen, wat voldoende moet zijn, EN er is 3 jaar garantie...
nu weet ik alleen nog niet welke pixelgarantie er is bij sony. weet iemand daar meer over?
als die meevalt, koop ik het zeker...no votes
