Pagina 1 van 2 12 LaatsteLaatste
Weergegeven resultaten: 1 t/m 20 van 30
    Member
    x
    36
    MTW2: The Lion Of Flanders - Flanders Faction Mod
    http://www.twcenter.net/forums/downloads//5_2c9.jpg
    Description:
    This mini-mod adds the Flemish as a faction to MTW2. With their own unique units such as the Goedendag Militia, Badelaar Militia
    and the Flemish Pikemen. Everything is included to make this faction as complete as the vanilla ones.
    DOES NOT REPLACE ANY ORIGNAL FACTIONS.
    Features:
    -Adds the faction County of Flanders to MTW2.
    -Faction has 30 units.
    -County of Flanders start with the province of Bruges.
    -Faction campaign description, units, banners,faction logo, merchants, diplomats,...
    -Historical faction Leader.
    -Unique units such as the Badelaar Militia, Goedendag Militia and Heavy Goedendag Militia.
    -The Army relies heavily on Militia units.
    Installation:
    Extract the RAR in too the MTW2 Folder. (for instance "c:\program files\MTW2")
    After the extraction is complete you'll find flandersfaction.bat in the MTW2 Folder, simply click this twice to run the mod
    NOTE: if you want the small ingame movies to work (such as the assasination movies for example) do this:
    Open the Data folder in MTW2 Directory, then open the fmv folder and select the following folders:
    -assasinate
    -event
    -generic
    -infiltrate
    -sabotage
    Right click and then click copy.
    Then open the flandersfaction folder in the MTW2 directory (NOT THE FLANDERSFACTION FOLDER IN THE DATA DIRECTORY), open the fmv folder
    and paste the folders you copied before in it. Done.
    Permissions: Free To Use
    Download:
    http://www.twcenter.net/forums/downl...o=file&id=1254
    http://www.twcenter.net/forums/downloads//11_X6d.jpg
    http://www.twcenter.net/forums/downloads//1_49D.jpg
    http://www.twcenter.net/forums/downloads//13_d6H.jpg
    http://www.twcenter.net/forums/downloads//10_h9P.jpg
    Member joriske18's schermafbeelding
    23/01/04
    merksem
    4.035
    17 (100%)
    ziet er leuk uit, vanavond is downloaden en testen
    Member jan1978's schermafbeelding
    22/12/02
    Sint-Truiden
    1.322
    kickass, straks uitproberen!
    Crew Member el shorty's schermafbeelding
    10/07/02
    2.112
    vet. Direct ook eens downen en testen.
    mooi gemaakt
    * blub*
    Member
    13/11/03
    Zottegem
    221
    zitten er nog andere mods bij ook? Zoals die fixed 2H mannekes en AI enal?
    Banned
    3/02/06
    Middelkerke
    2.508
    17 (100%)
    had ik da maar gehad voor mijn gulden sporen slag-video. ( http://users.skynet.be/fa555138/movi...sporenslag.avi )
    Member Avondland's schermafbeelding
    3/12/05
    Boechout
    12.425
    Weblogs
    21
    Ziet er leuk uit maar véél te kleurig en het valt op dat de vlaggen er veel te modern uitzien, hoewel ze inderdaad natuurlijk de heraldische leeuw voorstellen.
    Member
    13/11/03
    Zottegem
    221
    http://users.telenet.be/marklar/0006.jpg
    Da werkt nie zo goe bij mij, iemand dat dit ook heeft voorgehad?
    Kheb ook nog die darth mod staan, zou het kunnen dat ze niet goed overeenkomen?
    Member
    x
    36
    Zou best kunnen dat het niet werkt met darth mod ik heb nog geen kans gehad om de mod met andere mods te testen.
    Member AhReNd's schermafbeelding
    Opwijk
    2.226
    Zalige mod, hier en daar nog een paar foutjes, maar dat geeft niet.
    Dankzij Deze mod, heb ik terug zin gekregen in M2TW
    Opwijk
    2.226
    Iemand die met deze mod aan het spelen is? Zoja, kun je je verloop ff snel weergeven.
    Ik heb atm Bruges, Antwerp, Rheims. (beurt 11), maar ondertussen heb ik met al mijn buurlanden oorlog..
    hoe zijn jullie vooruit gegaan dus?
    Member
    7/06/05
    3.211
    17 (100%)
    Omg zalig.
    Direct eens testen
    Member
    7/06/05
    3.211
    17 (100%)
    Mooi, zeer mooi.
    Ik ga wel even zeggen dat je bij de faction selection bij een nieuwe campaign wel degelijk Flanders kan kiezen, je ziet hun wapenschild echter niet staan. Het is dus een onzichtbare knop. Ik was al mijn files aan het uitpluizen of ze wel playable waren aangeduid eerdat ik het doorhad
    Goede mod, anyway
    Member deyoeri's schermafbeelding
    17/08/04
    Duisburg
    3.136
    Zeer coole mod!
    Maar ligt het aan mij, of kan ik mijn missions niet meer bekijken :/
    Member EternalSilence's schermafbeelding
    23/01/04
    14.732
    direct downloaden
    eens frankrijk van de kaart vegen
  16. #16
    Opwijk
    2.226
    Citaat Oorspronkelijk geplaatst door deyoeri Bekijk bericht
    Zeer coole mod!
    "NOTE: if you want the small ingame movies to work (such as the assasination movies for example) do this:
    -assasinate
    -event
    -generic
    -infiltrate
    -sabotage
    and paste the folders you copied before in it. Done."
    readme is lezen eh .
  17. #17
    17/08/04
    Duisburg
    3.136
    Ik bedoelde niet de filmpjes, maar waar ik kan kijken hoeveel turns ik nog heb bv om een missie van de paus te volbrengen.
  18. #18
    23/01/04
    14.732
    zal er wss niet in zitten
    btw: heeft die mod invloed op u bestaande savegames, en u eerdere campagne's met u landen
    want als ge dan zo heel vlaanderen al hebt ingepalmd, en dan de mod installeert, ga da dan geen conflicten geven?
  19. #19
    17/08/04
    Duisburg
    3.136
    Citaat Oorspronkelijk geplaatst door Doom Dragon Bekijk bericht
    Mod functioneert appart van uw bestaande save games dacht'k.
  20. #20
    Member
    x
    36
    Normaal zou het moeten werken, heb je mss nog een andere mod geinstalleerd?
    En het werkt idd niet met bestaande savegames.
Discussie informatie
Users Browsing this Thread
