Pagina 40 van 116 EersteEerste ... 303637383940414243445090 ... LaatsteLaatste
Weergegeven resultaten: 781 t/m 800 van 2304
  1. #781
    Approved 9-lifer demon326's schermafbeelding
    18/04/03
    13.605
    20 (100%)
    Weblogs
    3
    Er hangen hier veel stapelwolken en enkele hebben het buienstadium al gehaald waardoor er af en toe wat regen valt
  2. #782
    Platinum Member GaMe®'s schermafbeelding
    Tongeren
    12.570
    86 (99%)
    Estofex lvl 1 (voor tornado's) ligt net over de grens met Duitsland morgen. Toch waarschuwt het KMI voor hevig onweer in het oosten van ons land.
    Central Germany to southern Benelux
    As the frontal wave passes by, a tongue of rich low-level moisture will advect north-eastward into western Germany. Although lapse rates are weak, QG forcing ahead of an approaching mid-level jet streak may provide enough lift to enable CAPE. Latest GFS indeed indicates weak CAPE during the day. Given the strong forcing and weak CIN, showers and thunderstorms are expected. Most updrafts will be weak due to the weak CAPE. However, vertical wind shear will increase along the northern nose o the moist air mass due to the approaching jet streak, and deep-layer vertical wind shear may exceed 20 m/s in the late afternoon hours. Additionally, the 0-1 km bulk shear will be strong along the warm front (10 m/s) and favourable veering profiles are expected. Some storms may therefore evolve into supercells capable of producing tornadoes. The main thread seems to exist in the afternoon and evening hours, when the mid-level jet approaches and the overlap of vertical wind shear and CAPE will be greatest. However, the greatest uncertainty will be the cloud-coverage and rain leading to a cool boundary-layer and weak chanced for thunderstorms. Later observations will indicate if the scenario of storms will really come true.
  3. #783
    18/04/03
    13.605
    20 (100%)
    Weblogs
    3
    Volgens het weer bericht vandaag zou er een lijn van west naar oost trekken, maar eerst maar eens zien, dan geloven
  4. #784
    Member
    10/07/09
    Vlaams-Brabant
    1.037
    Kan ik ergens de weerswaarnemingen vinden van 10 dagen geleden?
    De verzekering vraagt op welke datum en welk uur de storm raasde die mijn dak beschadigd heeft. Probleem is dat ik dat weekend in het buitenland was en dus niet concreet weet wanneer die storm plaats vond (maar ik weet wel dat er eentje was). Kan ik dat ergens terugvinden?
  5. #785
    Tongeren
    12.570
    86 (99%)
    Citaat Oorspronkelijk geplaatst door Indigoke Bekijk bericht
    Ik zou het kmi eens contacteren. Die kunnen u ook per brief een bevestiging sturen voor de verzekering dat er een blikseminslag bij u in de buurt heeft voorgedaan. Zo hebben ze ook kaarten met windschade over een periode van 24u.
    Producten & diensten - KMI
    Ofwel kunt ge het zelf hier opzoeken: http://buienradar.nl/historie.aspx
  6. #786
    18/04/03
    13.605
    20 (100%)
    Weblogs
    3
    Ik zie op de radar nu de lijn vormen waar men in het weerbericht over sprak..
  7. #787
    Member
    8/09/11
    Waregem
    252
    Mensen die vanmiddag richting Frankrijk trekken, moeten opletten voor grootschalig en hevig onweer ten zuiden van Parijs. Hagelstenen tot 4 cm en windstoten tot 120 km/h zijn bij deze buien niet uitgesloten!
    Voor de liefhebbers: Noodweer - weerbespreking Benelux :: onweer en bliksem :: weerarchief
    Onweer / sneeuw of storm http://www.noodweer.be
  8. #788
    Member
    23/01/11
    1.631
    Deze nacht MCS die onze richting kan uitkomen?
    Wsl niet aangezien Estofex de lijntjes met kans op onweer niet doortrekt.
    "There's no place for truth on the internet."
  9. #789
    18/04/03
    13.605
    20 (100%)
    Weblogs
    3
    Level 1 voor héél BE
  10. #790
    Member
    2/08/02
    Ninove
    3.817
    Kans op onweer zou eerder klein zijn in 't westen, in Limburg en Wallonië meer kans
    Er komt nu wel een groot regengebied deze richting uit, het mooie weer vandaag blijft dus niet duren. Alle bliksem zit aan het de zuidkant van dat gebied dus voor hier wordt het niks zoals voorspeld.
    Desktop: Intel Core i5-3570K 8GB RAM GTX680 256GB SSD Dell U2711
  11. #791
    Tongeren
    12.570
    86 (99%)
    Indien er zich vandaag een supercell ontwikkelt, zijn de parameters gunstig dat deze ook een tornado zal produceren. Zelfs in Belgie en zeker in Limburg.
    Voorspelling Karim:
    De modellen en evolutie in de situatie bevestigen de kans op zwaar onweer over het zuidoosten van BE en geheel LUX. Daar dieper in de TE850 tong en bij hoge shear & storm reletive helecity (SRH01km tot 220!) kunnen relatief gemakkelijk supercells tot ontwikkeling komen. Minpunt is de toch vrij bescheiden onstabiliteit met een CAPE amper rond 1000 J/kg en een LI amper onder -2. Maar de hoge shear kan dit grotendeels compenseren alsook de verwachtte dynamische triggering. Dit gebied bevindt zich ook in de uitgang van een vrij krachtige jetstreak wat eveneens een aandachtspunt is.
    De kansen op wateroverlast op grote schaal lijken minder van tel, des te meer het gevaar voor windschade met een Ivens rond 100 km/h. Ook het opvallend lage LCL niveau (met dus vochtige PBL) wekken de aandacht en indiceren verhoogde kansen op een lokale tornado bij een supercell.
  12. #792
    18/04/03
    13.605
    20 (100%)
    Weblogs
    3
    Citaat Oorspronkelijk geplaatst door GaMe® Bekijk bericht
    Het is goed warm hier buiten, zo een goede 25 graden en vochtig ook nog.... Als hier niets van komt, weet ik het ook niet meer
  13. #793
    Member
    13/01/04
    435
    Buienradar.nl - Europa
    iemand die de extreme bliksem kan verklaren in de atlantische oceaan?
  14. #794
    18/04/03
    13.605
    20 (100%)
    Weblogs
    3
    Onweer lijkt netjes onder ons land door te trekken, hoewel er boven frankrijk ook wat kleine onweerders ontstaan ...
  15. #795
    Member
    2/08/02
    Ninove
    3.817
    Citaat Oorspronkelijk geplaatst door Raffin_fcb_fan Bekijk bericht
    Lijkt mij een fout, nauwelijks wolken daar
  16. #796
    Member
    7/08/06
    930
    lijkt mij eerder de geschiedenis van bliksems boven frankrijk?
    Only last week, I murdered a rock, injured a stone, hospitalized a brick, I'm so mean I make medicine sick. - muhammad ali
  17. #797
    Tongeren
    12.570
    86 (99%)
    Ja, die radarbeelden hebben nooit goed gewerkt.
    Deze zijn 1000 keer beter:
  18. #798
    18/04/03
    13.605
    20 (100%)
    Weblogs
    3
    Groen is de zone waar er nog onweer kan plaatsvinden als het naar het NO gaat.
    Foto van weerwoord gehaald
  19. #799
    Member
    2/08/02
    Ninove
    3.817
    't is hier donker
  20. #800
    Member
    8/09/11
    Waregem
    252
    Hmm, de hele zaak begint nu fel te activeren boven het zuidelijk deel van België... Heb er ook direct een update moeten over schrijven, omdat het de komende 2 - 3 uur vrij interessant kan worden door de overlap met de hoge windschering / onstabiliteit
    Noodweer » 07.06 | verschillende luchtsoorten en onweersbuien
Discussie informatie
Users Browsing this Thread
