Pagina 1 van 2 12 LaatsteLaatste
Weergegeven resultaten: 1 t/m 20 van 25
Discussie: Koeningsegg
    Approved 9-lifer Garmir's schermafbeelding
    12/09/04
    Gentbrugge
    3.078
    117 (100%)
    Talking Koeningsegg
    Ik was even aan het rondneuzen en naar wat autokes aan het zien, tot wanneer een maat me een site gaf, een automerk dat ik nog nooit van gehoord had. Nu mogen ze me wel deze voituur geven
    Side Closed, picture
    Technical Date Koenigsegg CCR
    Performance
    Acceleration: 0-100 km/h (062 mph) 3.2 seconds
    Top speed: 395+ km/h (242+ mph)
    Standing quartermile: 9 seconds, end speed 235 km/h (146 mph)
    Braking distance: 31 m (1000 km/h)
    Lateral g-force: 1.3 g
    Fuel consumption: Highway travel: 13 l/100 km
    Combined: 17 l/100 km
    Body
    Two-door, two-seater with removable hardtop stowable under the front boot lid.
    The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam sandwich reinforcements.
    Dimensions
    Ground clearance: 100 mm (3.9 inch)
    Fuel capacity: 80 litres (17.6 gallons)
    Luggage compartment: 120 litres (26.4 gallons)
    Dry weight: 1180 kg
    Areodynamics
    Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis. Venturi tunnels at the rear of chassis/body.
    Side Open, picture
    Chassis
    Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
    Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
    Brakes
    Front brakes: Ventilated discs 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
    Rear brakes: Ventilated discs 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
    Wheels
    Koenigsegg magnesium alloy wheels with centre locking.
    Front: 19 x 9.5
    Rear: 20 x 12.5
    Tyres
    Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
    Front: 255/3519 (Y)
    Rear: 335/3020 (Y)
    Front, picture
    Steering
    Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres.
    Engine (click for more info about the CCR engineering specifics)
    Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
    Displacement: 4.700 cm3.
    Compression: 8.6:1
    Weight: 215 kg
    Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
    Oil: SAE 10W60 fully synthetic racing.
    Oil tank capacity: 12 litres (2.64 gallons)
    Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.
    Fuel: 98 RON unleaded.
    Ignition system: Direct coil on plug. Transistorised.
    Power output: 806 bhp at 6.900 rpm.
    Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
    Maximum rpm: 7.600 rpm.
    Transmission
    Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
    Clutch: Dual Plate, organic or cintered 215 mm (8.46 inch). Oil-cooled and electronically operated.
    Back, picture
    Equipment
    In standard mode the car is very well equipped with many items that competitors have as options.
    Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
    Standard equipment
    • Aluminium rear light casings
    • Detachable roof panel
    • Climate control
    • Electric rear view mirrors
    • Leather interior
    • Central locking
    • Electrical windows
    • Alarm with immobilizer
    • Toolkit
    • Driver side airbag
    • Power steering
    • Hydraulic ride height control
    • Servo assisted brakes
    • ABS
    • Traction control
    • Stereo with CD-player
    • Tyre pressure sensors
    • Car cover
    Customer options
    • Custom Color Leather Interior
    • Custom Paint Color
    • Parking Sensors
    • GPS Navigation
    • Sequentially operated gearbox
    • Rearview Camera
    • Fitted Luggage
    Foto1 | Foto2 | Foto3 | Foto4 | Foto5
    Foto6 | Foto7 | Foto8 | Foto9 | Foto10
    Koenigsegg Promo Filmpje, World Record
    Approved 9-lifer 128MB's schermafbeelding
    19/01/05
    Overpelt
    16.844
    16 (95%)
    mooie auto
    Member ComputerVISTA's schermafbeelding
    2/07/03
    Geraardsbergen
    57.294
    Is al op topgear geweest, die deuren zijn uber ^^
    Member eddy emmer's schermafbeelding
    Brasschaat
    267
    Is al een tijdje uit hoor, dus echt nieuw is hij niet. Als ik mij niet vergis is het het Zweeds/Finse (In ieder geval die kanten op) antwoord op al de Italiaanse superauto's. Hij is idd hl mooi en exclusief. Ik heb een tijdje geleden een boekje vast gehad waarin alle auto's stonden die je in 2005 kon kopen en als commentaar bij deze auto stond dat de kans dat je een marsmannetje tegen komt groter is dan dat je deze bolide ziet.
    De Top Gear reportage:
    http://video.google.com/videoplay?do...657&q=top+gear
    Super Moderator Dakantochnie's schermafbeelding
    31/01/04
    Het Stad
    16.793
    Goh zeg wat een on ge loof lijk coole auto...*vangt het slijm op*
    Ik had er al wel van gehoord, maar nu ik nog eens deftig naar de foto's kijk kan ik enkel maar besluiten dat hij ng mooier is dan ik dacht.
    Member LeSec's schermafbeelding
    Melbourne
    4.997
    Weblogs
    1
    Was de motor niet gebaseerd op Ford GT xx model?
    Kheb daar eens gans artikel over gelezen toen ik bij de dokter zat, het kwijl droop me idd ookwel uit mijn mond wel al paar jaar geleden toch ze, da bakske bestaat al tijdje
    Member EternalSilence's schermafbeelding
    23/01/04
    14.835
    heu?
    oud nieuws.. der zijn al auto's die rapper rijden dan die wagen
    Dat weet je allemaal als je regelmatig naar Top Gear kijkt ^^
    zalige auto
    wel enorm kostelijk
    ma goed.. de euromillions winnen en ge kunt er u zeker een stuk of 10 kopen
    Member rad1cal's schermafbeelding
    15/02/04
    330
    Kar is Zwaar op zijn muil gegaan in verlede gumball race :P was maar ene piemel lomp genoeg om daarmee zo nen afstand mee te proberen rijden.
    En over allemaal andere auto's die sneller rijden: 'k Weet nog nie zo zeker.
    Melbourne
    4.997
    Weblogs
    1
    hehe was op gumball 3000 h? kheb movie ier staan op pc ^^ wel grappig, stond binnen de kortste keren gans overhit en al, zo ne Koeningsegg is gwn het ideaal voortuig om naar een peperduur restaurant te rijden en te imponeren, hell alsge echt rijk zijt en ge wilt nog opvallen, dan moete gwn zo iets exclusiefs hebben
    Member slash's schermafbeelding
    Sint-Truiden
    3.295
    oud nieuws ken em toch al ne hele tijd
    Member spray-bunny's schermafbeelding
    12/07/03
    Mount Zion
    10.257
    Is dit de opvolger van de C12?
    edit: nee, ik verwar met de pagani zonda c12
    Member
    21/11/03
    oudenaken
    4.718
    wa is de prijs van da spul eigenlijk, van de italiaanse auto's is da vrij simpel te vinden ma van deze vind ik da nooit (its always nice to be able to dream )
    Laatst gewijzigd door Dakantochnie; 1 februari 2006 om 18:57
    Member Liquid LP's schermafbeelding
    7/08/04
    1.013
    de prijs zou hier overeenkomen met iets van een 5-600.000€ schat ik.
    de koeningsegg is voor mij de indrukwekkendste supercar ooit.
    een van de lichtste supercars ook, ik weet maar 1 die nog minder weegt en dat is de mclaren f1. voor de rest heeft em niet zoveel pk ivm andere wagens in die klasse, maar de cilinder inhoud is ook kleiner (pk's zijn opgehaald met supercharger).
    op prestatie gebied moet hij voor geen enkele wagen onderdoen, behalve de veyron. maar moest ik kunnen kiezen tussen ne veyron of ne ccr, dan was't de ccr by miles.
    Grtzz,
    Liquid
    Member daFour's schermafbeelding
    28/04/04
    Oostkamp
    2.602
    16 (100%)
    heeft wat mee van een lamborghini ..niet mis , zeker niet ,behalve de achterlichten zijn wat tuning stijl :d
    Approved 9-lifer Soundstorm's schermafbeelding
    13/06/03
    12.233
    Die in Gumball was de CC en niet de CCR als ik mij goed herinner. Was ook een van de eerste die verkocht was.
    Is dan ook logisch dat daar iets mee misgaat h, ge moet da ook nie in uw kop halen om daar dan 3000 mijl mee te rijden h...
  16. #16
    7/08/04
    1.013
    Citaat Oorspronkelijk geplaatst door daFour
    die lichtjes zijn gewoon hella lichtjes... veel supercars gebruiken die ze, pagani zonda, ferrari's, weisman(n?), spyker c8, etc. zijn in feite meestal gewoon dezelfde lichten met aanpassing, in dit geval een gewoon alu rondje rondom voor de afwerking.
    maja, over smaken valt niet te discussieren.
    Grtzz,
    Liquid
  17. #17
    Member Mr Syphon's schermafbeelding
    5/11/03
    Beringen
    9.182
    Citaat Oorspronkelijk geplaatst door rad1cal
    waren de bugatti veyron en se saleen 7 ni sneller ?
  18. #18
    Member schep's schermafbeelding
    15/01/04
    2.108
    32 (100%)
    ken ze ook al een tijdje hoor, idd ubercool
    /edit: kijk maar eens
  19. #19
    Member Seraph's schermafbeelding
    4/09/02
    3.859
    Member GenghiS_KhaN's schermafbeelding
    1/09/02
    911
    24 (96%)
    Citaat Oorspronkelijk geplaatst door Liquid LP
    Grtzz,
    Liquid
    tis Wiesmann en Koenigsegg, ni weisman en koeningsegg
Discussie informatie
Users Browsing this Thread
