Plans for the Staff of Herding —Found in Act 4. It’s a random drop from Izual. Kill Izual for Blacksmith Plans for the Herding Staff (use the last waypoint). Head to The Great Span.
Black Mushroom —Found in Act 1. The Black Mushroom is located in a patch of mushrooms in Cathedral level 1 (second waypoint).
Leoric’s Shinbone —Found in Act 1. Leoric’s Shinbone is located at random in the fireplace (found by walking right when you enter) in Leoric’s Manor (use Leoric’s Manor waypoint).
Wirt’s Bell —Found in Act 2. Wirt’s Bell costs 100,000 gold in Caldeum’s Bazaar. To purchase it from a vendor, talk to the Squirt Merchant.
Liquid Rainbow —Found in Act 2 after you saved an NPC. To get to the Dahlgur Oasis use the Path of the Oasis waypoint. The Rare Merchant is located at the bottom of the map. Find the Mysterious Chest in the Mysterious Cave (a random dungeon).
Gibbering Gemstone —Found in Act 3 on the quest where you destroy the ballistae. Gibbering Gemstone drops from Chiltara, a RARE mob in the Caverns of Frost level 2. If you see Ice Cave Falls (AKA ice caverns) as a dungeon then you need to reload the game. Load using The Bridge of Korsikk waypoint.
Craft the Staff of Herding: Then you just need to get the recipe drop, pay your blacksmith 60,000 gold and craft it! (on Normal difficulty mode). How to upgrade your Staff of Herding: After you kill Izual in nightmare, before you kill Diablo, go to town and buy the nightmare Staff of Herding plans for 1 gold (vendor located by the healer/mercenaries) Note: All these items (besides Wirt’s Bell) are rare or random spawn or even both. So, you may have to do multiple run throughs. To enable it on higher difficulties you need to find the recipe on that level and pay the blacksmith again. In total you need:
Normal –150,000 gold.
Nightmare –200,000 gold.
Hell –500,000 gold.
Inferno –1 million gold.
Wanneer je uw staff hebt, loop daarmee van old tristram waypoint terug naar newtristram
Langs de weg ( onderkant ) zie je cowking spawnen uit beenderen zie wel dat je uw staff meehebt.dan opent hij een portal naar secret pony level.
LinkBack URL
About LinkBacks
Met citaat reageren
nuuBs!
